Qarl
Sep 23 2003, 09:38 PM
Nice clean hubs. I taped off the bearing surfaces before blasting. Shorter studs will be pressed in this weekend. They were set up for 1" spacers because of the Phonedials that were on the car before.
Aluminum cross member was blasted as well (after cleaning all the crud off first).
Carl
Sep 23 2003, 10:12 PM
Karl,
What an amazing project. You're patience and attention to detail is remarkable. Thanks for sharing your progress with us.
Carl
Brad Roberts
Sep 24 2003, 01:35 AM
My parts look better.. my parts look better.. Pics tomorrow evening.
Good job Carl. Everything looks nice and clean.
I mean K-a-r-l.
B
Qarl
Sep 24 2003, 07:56 AM
t-u-r-d
Qarl
Sep 25 2003, 09:40 PM
Fuel tank is done.
It was blasted, powdercoated, sealed with the POR tank sealing kit (you do this carefully AFTER the powdercoating), fuel line fittings redone, fuel sender refurbed, new gaskets, and new hardware.
Voila
Qarl
Sep 26 2003, 04:49 PM
Brad Roberts
Sep 27 2003, 03:55 AM
Karl.. I split the topics. We have a ton of control over the BBS. We can split and move threads at will.
B
Qarl
Nov 5 2003, 11:25 PM
Finally did a rough assemble of the rear suspension..
From this...
to this...
I pick up the powder coated front struts tomorrow!
and other good news. Hunter is coming home tomorrow!!!!
Yipee...
swood
Nov 5 2003, 11:37 PM
Very Very cool Qarl!
rick 918-S
Nov 6 2003, 12:45 AM
Nice work Karl. Hows your boy?
Swood Is that your car on your avatar? Coool color.
Curvie Roadlover
Nov 6 2003, 05:04 AM
Karl, your car is going to be SO SWEET when you're done, that you're going to have to hire a bevy of supermodels to sprinkle rose pedals on the road ahead of you wherever you drive.
You also may want to think about purchasing a set of velvet ropes to put around it when you're parked in public areas.
Jeroen
Nov 6 2003, 05:42 AM
Looking good!
And the fact that Hunter is coming home is even BETTER ! ! !
cheers,
Jeroen
Eric Taylor
Nov 6 2003, 08:16 PM
Oh man karl, This car is gona be the king kong of all 914's. What piece isn't powdercoated:)
Eric
URY914
Nov 6 2003, 08:29 PM
I see you're not using the spacer.
Don't like living on the edge?
Paul
TimT
Karl, what brakes are you using?
glad your boy is coming home
Qarl
Nov 6 2003, 08:47 PM
The "spacer" is actually a 4 to 5 bolt adapter from the PO. The new car will have 9x16 fuchs in the rear...
d914
Nov 6 2003, 08:51 PM
aren't any of the parts actually in the garage. I more of your house than the garage.
Nice to see your son home...
scotty
Nov 6 2003, 08:52 PM
Nah...with a 914, you can have
two trunk monkeys!
Since time = $$$, I think Karl's got the first $1,000,000 914!
Qarl
Nov 7 2003, 05:16 PM
Who says Bilstein front strut housings have to be Bilstein green? Why can't they be Bilstein Yellow? The powder coat color (signal yellow) is pretty darn close to Bilstein yellow.
They should come together this weekend!
redshift
Nov 7 2003, 05:19 PM
This is going to be a very, very nice parts car!
Watch your back!
M
Aaron Cox
Nov 7 2003, 08:34 PM
schweet! is thing goin into a museum? ever gonna see a road?
dsmeyer
Nov 8 2003, 06:01 AM
You may want to consider painting parts of your brake rotors.
Otherwise they will start to rust the minute they see any water.
I masked off where the pads contact the rotors and then sprayed on a high temp gray paint.
Then I baked them in the oven per the intructions on the can.
I also masked the area where the hub and the rotor mate to keep the surfaces true.
This was done at least five years ago and it holds up fine for a street car.
dsmeyer
Nov 8 2003, 06:11 AM
Another picture of the painted rotor.
The strut is a RSR style raised spindle for a 16" wheel.
(can be raised a little higher than for a 15" wheel)
Notice the reshaped steering arm and the gussets for reinforcement
where spindle welds to the shock tube.
Qarl
Nov 8 2003, 09:40 AM
mmm... big ass brakes!
dsmeyer
Nov 8 2003, 10:12 AM
QUOTE(kellzey @ Nov 8 2003, 11:40 AM)
Just stock '86 930/Turbo Look brakes.
If I put brakes this heavy on my 914 it wouldn't go fast enough to need them...
Qarl
Nov 12 2003, 10:08 PM
Okay, my steering rack has been refurbished.
Bead blasted cross member
Repacked steering rack with new moly grease
Installed turbo tie rods
Installed Bump Steer Kit
redshift
Nov 12 2003, 10:28 PM
Your parts collection is nice!
You should build a car.
M
Qarl
Nov 12 2003, 10:32 PM
Thanks. I was thinking of doing that... maybe some day.
redshift
Nov 12 2003, 10:35 PM
We have bets on if you finish or not.
M
Andyrew
Nov 12 2003, 10:39 PM
Nice rack!!!
(sorry, couldnt help myself
Qarl
Nov 12 2003, 10:42 PM
Finish what? Collecting parts? I will never finish collecting them...
redshift
Nov 12 2003, 10:51 PM
lol Andrew!
Karl, you fail to see that you are under scrutiny by the central scrutinizer.
What's the time frame? Side bets!
M
Qarl
Nov 13 2003, 12:28 AM
redshift
Nov 13 2003, 12:29 AM
lol
We are the only people who would have a kegger over a pile of wires like that..
WOOHOO!
M
Jeroen
Nov 13 2003, 12:32 AM
So, where did you find it?
cheers,
Jeroen
Qarl
Nov 13 2003, 12:34 AM
Miles,
I like how you sit in the shadows lurking... just waiting to reply to my posts...
redshift
Nov 13 2003, 12:36 AM
Don't make me pull out the big red G.
M
Qarl
Nov 13 2003, 12:42 AM
Long story on the harness...
I bought it about two years ago (before I even owned the current 914). Sold it about six months ago...
Recently re-acquired it!
This is my old picture.. but it will be back in my posession soon!
I still saved considerablly from what AA wanted for the only other one I could find!
ArtechnikA
Nov 13 2003, 07:34 AM
QUOTE(kellzey @ Nov 12 2003, 08:08 PM)
you may not need the bumpsteer kit with the reshaped steering arms on the RSR struts; they're both correcting for the same geometry/placement factor. my guess is the steering arm change will get you into the ballpark and you'll need at most a teeny shim under the rack to make it perfect. unless you're also relocating the rack in the tub, in which case i donno ...
i'll contact you offlist about pricing and sourcing - i want those struts (possibly the 15" versions) on my 911 this winter ...
BTW - fog light seals arrived just fine, thx.
Qarl
Nov 13 2003, 08:43 AM
Those RSR struts aren't mine. They belong to another dsmeyer!!! I have regular Bilstein struts.
dsmeyer
Nov 13 2003, 02:10 PM
QUOTE(kellzey @ Nov 13 2003, 10:43 AM)
Those were standard Bilstein struts, before the spindles were raised,
rewelded and gusseted. The steering arm was reshaped and then
the whole strut was powder coated green.
That's why I called them RSR "style" struts.
Qarl
Nov 20 2003, 07:15 PM
It lives... I actually DO have a car body to put all those purdy parts on to.
Car is primered. Flares are getting smoothed out. There are very few dimples in the body to be repaired. The body guy is amazed how straight this car is.
JmuRiz
Nov 20 2003, 07:23 PM
Wow, all those seams look GREAT w/o all the goop from the factory. I forget, did you remove that, or did your body guy? I hear it's a B to remove, but boy does it look good w/o it.
redshift
Nov 20 2003, 07:25 PM
I am going to cry.
M
Qarl
Nov 20 2003, 11:37 PM
Fu__ed a bearing up. Another one is on the way. Thanks Mueller!
swood
Nov 21 2003, 12:14 AM
Way too many parts man! You'll never get that all back together. I'm sure you'll end up like me,with a box full of "extra" parts.
So cool you're doing it right! Can't wait to see it done. Are you going to hermetically seal it when you're done?
Qarl
Nov 21 2003, 12:21 AM
I'm thinking more along the lines of a giant "Space Bag" or the Food Sealer 2000!
Brad Roberts
Nov 21 2003, 02:12 AM
Karl,
we are neck and neck.. I dropped "blackie" off last week to the body shop and they kicked ass on it all week. The tubs look identical at this point...LOL
Thanks for the pics.
B
Qarl
Nov 21 2003, 09:55 AM
How about a "blackie" update!
Brad Roberts
Nov 21 2003, 02:49 PM
I need to merge all the threads I have started with the different pieces of the car. Update wil happen soon. The body shop has several digital camera's so I may have them shoot something for me (they are over an hour away from me with no traffic).
B
