QUOTE(GregAmy @ Nov 13 2023, 07:47 AM)
Ok, seems I can't quit you...
I was cleaning up the garage yesterday from the mess I made with this project. Came across the old pulley hub (with its slice of key still in the groove) and decided to add it to my "wall of shame" of failed parts I have (when you get into racing you tend to collect stuff like this).
On the shelf, I picked up the broken crankshaft from 2019(?) and was going to slide the hub on there but the crank still had a key in it; I tapped the key out and noted that the key was damaged, offset like the old offset keys we used to use on VW overhead cams for timing. And there were scuff marks on the downstream side of the crank nose where its pulley was chattering.
So that engine's pulley was loose, too. I don't know if that was related to the crankshaft failure, but this certainly caught my attention.
I put the race car on the lift and checked its crank bolt - that engine uses a Bus fan and shroud - and that bolt, too, was slightly loose, about 1/16 of a turn to get it to 23 ft-lbs. So I removed the bolt, loctite blue'd it, and reinstalled to 30 ft-lbs. And I know who built that engine and I know he would not have missed something like this.
One time is random; twice is coincidental; three times is a trend. I think we have a trend going on here. I certainly seem to...
Does anyone know the class of bolt that's being used here? The markings on it are not standard. If it's equivalent to a 10.9 then most charts are showing in the 40 ft-lbs range. The underside of the bolt has locks similar to a Schnorr washer, and I'm sure the engineer didn't want that taper to get hammered in too tight (it would be a bitch to get loose).
However, I noticed all three crank washers have a circular groove where those locks have dug in; if that groove is too deep then the locks may be making less grip contact. Are these supposed to be single-use bolts and washers?
Maybe I'm overthinking this thing, but I've now experienced three potential failures, just in my own garage. So I'm'a thinking that proper torque, Loctite Blue, and maybe new bolts and washers is in order here. And maybe a higher torque value.
Has anyone else checked theirs? What have you found? - GA
That key looks like a specially designed offset key, not a damaged stocker.
That's weird!
Normally special keys like that are used to offset cam timing and not offset the hub alone...
For the reason why all of your crank hardware appears to loosen over time.
This is a bit of a guess on my part but it's worth thinking about.
The Type 4 engine has no vibration damper on it.
In its stock form it probably works fine without a damper.
Each power stroke applies individual power "spikes" into the crank. As these spikes increase in intensity and cycle rate this hammering can induce resonance into the crank assembly.
Making the rotating mass heavier reduces this tendency. All of the dual mass flywheel that are in use today are stupid heavy.
Slowing the rotating mass down helps combat this as well but that's not "sports car".
Adding some type of elastomer in an external pully is how these issues have been delt with in the past by most manufactures.
A complete BS "power upgrade" for many cars is a solid crank hub and lightweight smaller diameter drive pully. Sometimes these were listed as a "power pully."
What you get with one of the puppies is accessories that don't work worth a shit at idle and excessive crankshaft resonance.
You end up with broken locating keys, torn up crankshafts, loose crank bolts, and crank driven oil pump explosions (this is very common!!!).
I REMOVE "power pullies" whenever I find one...
A stock balancer is vastly superior to one of these.
For street cars I try to use a "Fluid Damper" if it's available for that engine.
Fluid Damper is awesome at eliminating harmonics and resonance below 6500-7500 rpm.
For an engine constantly operating at or above those numbers I prefer a tunable elastomer balancer (you can get different O-rings for these) or a specific balancer for high rpm use. It will be listed as a "tuned" balancer and it should spec out an RPM range where it is effective.
The T4 has no harmonic balancer anyway.
Most performance oriented T4s are using much lighter pistons and rods and being spun to higher engine speeds.
It looks like most decently built T4 have at least 50% more power than stock and some double the stock power levels.
I agree with Jeff.
I'll be spending extra time on the crank snout and pully interface.
30lbs sounds good too.
New hardware (maybe upgraded) should be incorporated.
Medically clean threads and blue Loctite will be used.
Once a year inspections (maybe more often?) will be done.
My thoughts...
Maybe wrong?
And now SuperHawk will produce a white paper showing something else...
