[quote name='johnnymiz' date='Apr 16 2024, 11:24 AM' post='3139874']
[quote name='rjames' post='3139873' date='Apr 16 2024, 11:21 AM']
[quote name='johnnymiz' post='3139866' date='Apr 16 2024, 07:36 AM']
i installed 914Rubber LED headlights. now, when i pull the fog light switch, the fog lights do not go on.. but the headlights switch to high beam. also, the high beam indicator doesnt light up in either case when the high beams are on.
assuming i know NOTHING about automobile wiring, how would i go about rectifying this.?
i saw in another thread to ground out the white/blue wire going to the number one fuse.
what, exactly, does that mean? do i have to take the fuse panel off the dash to get to it?
thanks in advance
[/quote]
Yes. Take the fuse panel down (just 2 screws holding it in under the dash I believe) and find the blue/white wire. Unplug it and connect it to the ground post above where the fuse panel sits under the dash. You'll need to change the spade connector on the wire to secure it to the post.
Pictures of the wire and the ground post here:
LED/Fog light fix[/quote]
So, to be clear, i change the spade connector attached to the two white/blue wires that i took off the top of fuse 1 (the blue one), and attach it to the ground post...... Yes?
