Full Version: Brain fart regulator question
Pages: 1, 2
mb911
QUOTE(Spoke @ Jun 20 2024, 04:05 PM) *
QUOTE(mb911 @ Jun 18 2024, 05:39 PM) *
dF is weird as I get different values depending on what 12 pin connection I check.
What does the 12 pin connection have to do with DF? In the 914/4, DF goes between the alternator and the VR and goes through the 3 pin connector between them. That's it.
Did you do some tests on the 3 VR voltages while running? This can tell a lot about your system.
When running, measure these voltages at the VR:
D+ should be 13-14V
DF should vary between 5-10V depending on electrical load.
D- should be 0V
Also measure the battery voltage:
B+ should be 13-14V and follow D+
Measure all voltages with respect to a chassis lug, not the engine case.
For the field test, remove the VR and short DF to D+ then start the engine. This should force maximum voltage of about 16V on D+ and B+. Do this for a short burst as it's hard on the battery and alternator.
As an aside, my '86 930 was showing low battery voltage (12V) and slow starting. I bought a new battery and immediately got 13.5V steady. You mentioned you were going to replace your 10 year old battery. Did you replace it and did it make a difference?
Changed battery, no change, did full load test and shot up to 15.5-16 volts short burst. Everything points to VR so ordered a new one. Waiting for that to be delivered
JamesM
QUOTE(mb911 @ Jun 17 2024, 11:10 AM) *
This wiring picture just broke my OCD
mb911
QUOTE(JamesM @ Jun 20 2024, 07:32 PM) *
What wiring no picture? No idea what you’re talking about. It’s a bunch of wiring in small space which includes MSD, ECU, wide band o2 . There is no other spot for it and I feel like it’s pretty straight forward
mb911
Well it was a combination of things. Ignition switch replaced (911 style), fuse panel needing cleaning, a few grounds cleaned up and all set now
Superhawk996
QUOTE(mb911 @ Jun 26 2024, 10:16 AM) *
mb911
QUOTE(SirAndy @ Jun 26 2024, 10:48 AM) *
It’s amazing something so silly caused this but glad it’s taken care of now time to learn MS autotune.
