anthony
Oct 22 2006, 05:31 PM
I'm curious if stock 911 nikasil cylinders are cast or billet?
cnavarro
Oct 22 2006, 05:55 PM
factory Mahle/KS 911 cylinders = cast, centrifugally.
Bleyseng
Oct 22 2006, 06:23 PM
I just think that people here in the know are from the "Show Me" state which ain't bad until these are tested.
I hope these do work out and can replace the iron cylinders out there (AA) so we also have the choice to use em. Ahh, I am dreaming but one can only hope as it would be nice to have that extra cooling from aluminum cylinders for more stockish motors.
Still sitting on my Nickie 103mm's for my next motor...now to find that pot of gold so I can afford to build it.
anthony
Oct 22 2006, 06:41 PM
Charles, have you guys explored making a less expensive cast Nickies type product?
There is obviously a need for a nice 96mm drop in solution. The only choices now are cheap AA cylinders or finding OEM 94mm cylinders that are good and having them honed to 96mms. There would obviously be a high demand better performing aluminum product that could come in at say $1000 for a set of cylinders and Keith Black pistons.
I'm just thinking out loud here and wondering if it's even economically feasible.
bd1308
Oct 22 2006, 06:47 PM
Yeah, say a nice small cast cylinder, even cast iron, with nickie plating on it, and call it Fickie, for Fake Nickie or something catchy like that
cnavarro
Oct 22 2006, 08:03 PM
FYI, I have plated cast iron cylinders - in fact, it works really well.
Little background. Way back when, before LN was LN and this was just a project, a cast cylinder was a consideration. Doing them billet was more or less just a means by which to get them done in short runs with low quantities. There have been many iterations when it comes down to what Nickies are machined out of. We started with an alloy similar in strength to the factory cylinders ~30,000 psi. We made tweaks from year to year (and batch to batch) until we ended up with the current alloy used which is ~52,000 psi (as high as 55k psi). Way stronger with ductility and % elongation that can't be matched by any casting alloy, that is why they work so well and are so forgiving. The type 4 stuff is just starting to scratch at their potential. The 911 guys have realized their potential - bigger bores, more boost, more compression.
Part of the beauty of the way I do things is the custom nature of the product and my flexibility. A big part of the cost is the process by which the material is made and the amount that has to be machined (and scrapped) to make the product. Sure, I could cast a blank and machine it, but it wouldn't be the same. That's what CMW did. They ended up just coming to me for custom cylinders. I don't want to compromise quality or anything else I have worked so hard to achieve, just to sell cylinders in volume. There is no way to compete with China. Not even plating OE cast iron cylinders.
I offered a biral cylinder back in the day. It was expensive to make and did not deliver the bang for the buck of Nickies. You're better off boring out an oe cylinder, cryoing it, and plating it for that kind of money.
cnavarro
Oct 22 2006, 08:07 PM
What the guys in china should have made was a quality biral in a 96mm- that's where a casting would be optimal - then you don't have to worry about rings, head studs, etc. They would work with stock head studs and you could use any pistons and rings. Hell, even make them in a 94mm bore and then they could be bored out to 96. You could even make a 98mm machine in and I think it would last for most applications in a biral. If I had the time and money, that would be a product I would want to offer to fill the void. I may still do it, but there are bigger fishes to fry at the moment.
Type 4 Unleashed
Oct 24 2006, 09:08 AM
gothspeed
May 5 2010, 03:30 PM
So what is the verdict on these??? Has anyone used them? If 50k miles from a set of 96s or 98s is possible, it would work for many people.
QUOTE(bd1308 @ Oct 22 2006, 10:09 AM)
Try just running them like theyre supposed to be run, instead of putting them under 30 # of boost and running 1200F head temps.
+1 a real life test would suffice, many components will not hold up to 'abuse'. I wouldn't expect them to be better than cylinders that cost a lot more, but if they last similar to cast iron, it would be pretty good IMO.
QUOTE(anthony @ Oct 22 2006, 04:31 PM)
Factory Mahle are castings. Probably a very controlled hi-tech process though.
Chris Pincetich
May 5 2010, 06:55 PM
If you can afford them, contact Len and get some Nikkies from LN Engineering.
They are the bomb. Reliable builds reported here with all sizes in a TIV.
No direct experience from me, I just read a lot.
gothspeed
May 5 2010, 07:13 PM
QUOTE(ChrisNPDrider @ May 5 2010, 05:55 PM)
They are cool
!! But $3000-ish for pistons, cylinders and head studs is a little steep IMO. Then I would be forced to spend more money on the rest of the motor as it would have to match the cylinders
Randal
May 15 2010, 08:27 AM
I'm sure others here have mentioned the importance of buying a product that is proven and works. In the case of a motor, especially a motor that isn't going to be stock, you want the absolute best parts. I mean why put something on your built motor that has any possibility of failing. Want to build it twice?
As to Charles, he's an absolute great vendor. He tells you everything you need to know, is always there to work with you, totally honest and basically a stellar guy.
Everything I have purchased from Charles has worked as he outlined and I've never had even one simple glitch with any of the product he sells.
Just a great all around, no drama, guy who has your interest as a first priority.
craig downs
May 15 2010, 09:29 PM
One of the reasons Charles has mentioned before why they are expensive is the nikasil plating he uses for his cylinders. It is the best he has found and thats why there is a life time guaranty on the plating not to flake. If you want the best you got to pay the price for admission.
gothspeed
May 16 2010, 01:50 AM
Well that settles it. Since the absolute 'best' cylinders for my 914 is not that important to me. Standard cast iron cylinders should do the trick
craig downs
May 16 2010, 01:21 PM
Good cast iron cylinders are fine up to 96mm
ME733
May 17 2010, 11:47 AM
..............Cast Iron Cylinders, are available up to 105 mm bores....And unless you expect to have an engine, producing over 50 H.P. per cylinder, Thats 200 actual H.P. total........then cast iron cylinders will work just fine....you will need an external oil cooler, as the H.P increases over about 125....The drama, expense, additional specalized parts and assembly techniques, are just not worth all the extra effort for a street car producing less than 150-175 actual H.P....In my opinion.
