mightyohm
Jan 8 2004, 02:32 PM
Does anyone have a good reference on how to set up valve train geometry specifically on the type IV? I think there's a book out on building performance VW engines, is it any good?
I'm still an engine rebuilding newbie, so be nice.
Mueller
Jan 8 2004, 02:41 PM
Jake,
switch to decaf my man, LOL
seriously, thanks for the hands on info, I was told by Joe Schubeck not to float the valves when I spoke to him on the phone before buying my lifters from LN Engineering.....
Jake Raby
Jan 8 2004, 03:22 PM
Yeah..... floating valves isn't a good thing at any time, no matter what kind of lifters that you have.
The cam I want to set you up with has such slow ramps that floating them is something that would require pure evil intention to do.
Korijo
Jan 8 2004, 03:33 PM
I just re-read the entire thread... Again. I am now going the ceramic lifter route.
Thanks for NUTHIN', guys
Mueller
Jan 8 2004, 03:39 PM
"pure evil"???
about shear stupidity??? yea, I'll be carefull
Hey Jake,
with that cam, would I lose anything hp or driving wise if a set of dual throttle bodies with EFI
accidently appeared on my engine instead of the stock 2.0 intake plenum??
Korijo
Jan 8 2004, 04:05 PM
What is the advantage of the oversized lifters compared to the direct replacement lifters ?
Charles, does LN have a payment plan or a lay-away plan ?
Seriously...
mightyohm
Jan 8 2004, 05:30 PM
You get the lifter bores bored out for the oversize lifters. So now you have a nice new lifter bore that is round and free of defects.
cnavarro
Jan 8 2004, 05:47 PM
Layaway. That's pretty funny, considering paypal had a new feature to finance big purchases appear in the merchant tools today. I was just wondering do they offer financing insurance, incase the person falls off the face of the earth? I am thinking of looking into financing purchases with a local bank for customers, but that is highly speculative.
I think we maybe need to get a drop-in group buy going for US customers. That will let me get the quantity up, so I can afford to actually do a group buy on them.
Charles Navarro
LN Engineering
http://www.LNengineering.comAircooled Precision Performance
Air_Cooled_Nut
Jan 8 2004, 06:02 PM
QUOTE(Elliot Cannon @ Aug 28 2003, 10:00 AM)
QUOTE(rhodyguy @ Aug 28 2003, 09:18 AM)
fly up and sit on my deck if you want to. SERENITY NOW!!
kevin
Thanks for the offer Kevin. I retire in 2years 8months ( but who's counting). My wife likes the Pacific NW so we may end up there. We visited the San Juans and a few of the smaller towns in the area and kinda liked it. My problem is, if it gets below 50 degress F. I lose conciousness. Anyways keep a spot open on your deck for me and I'll bring the wine, beer, whatever.
Cheers, Elliot
You're gonna be a dead man
Aaron Cox
Jan 8 2004, 06:32 PM
QUOTE(Brett W @ Jan 8 2004, 07:38 AM)
ONe thing you should check before you assume a bad cam, is the side play on the rocker arms. If you have to much side play you will still get valve train noise. With the valves adjusted PROPERLY roll the engine up to TDC for each cylinder and try and slide the rocker back and forth if you have more than a couple of thousandths you will have racket. You m,ay also try and adjust the valves a little tighter than the specs, I would only go about .001 or so at a time though and you will need to be much more diligent about checking your valves.
yeah...my rockers are pretty well worn. ill check the side play next time its on stands...thanks for the heads up!
i didnt know where to find new rockers/shafts when i built my engine. still dont! where can i pick up a set next time, and are all the rockers the same (ie 1.7, 1.8, 2.0)
Korijo
Jan 8 2004, 07:32 PM
I'm in for a "Direct" replacement group buy thing... *IF*...
the machine-in lifters won't benefit my engine-in-the-works (see specifics below). My case
IS apart. And have my cam/lifters all ready, but they are the perfect canidates for ... (booming voice) ... "THE LIFTER CAM ISSUE".
Here are my projected spec's:
94mm Flat tops (already cut for valves)
78mm CW Demello Crank
H-Beam Rods (lightened-clearanced whatever)
86 Web Cam/solid lifters
40mm IDF's
HD Springs
Stock Valves
Swivel Head Adjusters
Not to mention my heads, remember ?? Everyone is/was scared of them
The dreaded seat staking...
rhodyguy
Jan 8 2004, 09:00 PM
is buying a set up from cb performance an option. no web cams. what are the chances that THEIR lifters will be compatible with THEIR cams.
kevin
Jake Raby
Jan 9 2004, 08:54 AM
That combo needs some serious refiguring in my opinion...
where are you getting a 24pinned H Beam rod? bushing the piston? Be ready for serious clearance issues with those pistons if you use a stock length rod.
There are many better cams for the combo as well, the 86 does not like CR at all, and has lazy ramps. its my stock replacement in 100% stock engines otherwise.
Korijo
Jan 10 2004, 01:05 AM
I thought I was lacking in the cam department
Guess I was thinking the ceramic lifters might take up the slack...
The rods are bushed to 22... 5.5" (IIRC). Pistons have ALREADY been clearanced for up to 78 stroke. Oh- I have Berg cylinder shims, too.
My initial question was... "What is the benefit of a larger lifter ?"
Mark Henry
Jan 10 2004, 08:13 AM
QUOTE(Korijo @ Jan 9 2004, 11:05 PM)
Dave, Jake is talking about your pistons. If they are made for a stock T4 rod then they have a 24mm pin. Your chevy (journal) rods have a 22mm piston pin. you will need different pistons.
Lifters don't add anything lift wise, the cam and rockers do that. The machine-in lifters are a hair bigger around, machining the bore corrects 30yrs of wear in the lifter bores. You can now get drop-in ceramic lifters.
You might want a tad bigger cam.
Korijo
Jan 10 2004, 03:49 PM
I know. My pistons are Type 1, with 22mm pins. Guess I should have said that
So the bigger bore, machine-in ceramic lifters WON'T benefit my engine MORE than the drop-ins ? My case has already been align bored, so maybe the lifter bores need some attention. Now's the time to do it...
Yea, I figured
. What cam works best with the ceramic lifters ?
theo
Jul 23 2013, 01:52 PM
Sorry to dig up a decade old thread, but does anyone know if there was any resolution to this issue? I can’t really seem to find any recent discussion of why these lifters were failing. Are the WEB lifters that are currently on the market reliable?
monkeyboy
Jul 23 2013, 02:05 PM
General concensus these days was that a lot of it had to do with the oils changing due to new smog regulations.
Nowadays we run "High Zinc" oil. Make sure it is specified to have high zinc and phosphorus. For use with flat tappet cams is what you are looking for.
Joe Gibbs makes an oil specifically for use in air cooled motors.
Elliot Cannon
Jul 23 2013, 03:45 PM
I found some ceramic lifters. ($500) Works great and apparently unobtainable now.
7TPorsh
Jul 23 2013, 04:07 PM
worn
Jul 23 2013, 09:45 PM
QUOTE(redshift @ Aug 29 2003, 11:21 PM)
Built by the best, for the best money work can buy.... yeah, I feel good, if not inconfident.
I have webcams and what appear to be twopart lifters. I feel ok, if incontinent.
sean_v8_914
Jul 24 2013, 09:23 AM
lots of high zddp oils coming out because of this. Lucas, brad penn, valvoline. look on summit racing.com
Jake Raby
Jul 24 2013, 07:03 PM
Yep...
This...
Led to this after several generations of development in my engines.
And its not just Zinc. Attend one of the lubrication Seminars hosted by Lake Speed of Joe Gibbs Driven Racing Oils to learn how we developed these oils and how the critical balance of anti-wear and detergency packages is is so critical. Lake is a Certified Lubrication Specialist and Tribologist. His seminars are NOT infomercials, in fact he hardly talks about Gibbs products unless the attendees ask him.
Joe Gibbs products are formulated by Lubrizol; one of only 4 companies in the world that makes additive packages for oils. Interestingly enough, ZDDP was invented by Lubrizol. No one knows it better and every single piece of military equipment in the US Armed Forces is filled with Lubrizol oils, in fact ZDDP was invented to kill engine wear in Sherman Tank engines in WWII.
worn
Jul 24 2013, 08:11 PM
So I will be ok as long as I use joe Gibbs oil? That is good to know because I have new set of lifters and I was getting concerned. I will check out Summit.
Jake Raby
Jul 24 2013, 08:55 PM
QUOTE(worn @ Jul 24 2013, 06:11 PM)
Oil isn't magical. If you have mismatched components or low quality components with improper profiles, improper spring pressure or etc you will have problems no matter what oil is used.
We have not had a single camshaft issue since 2005, before that we had gone 5 years with zero issues. that single issue that we had was in my own engine!
Thats turnkeys and component kit sales alike and the numbers are in the thousands for sales.
A lot of it is luck. Good oil at least gives you a fighting chance. Bad oil gives you a death wish.
