nick mironov
May 4 2007, 08:21 PM
The hood vent experiment worked, but the heat flowed back into the cabin through the front ventilation inlet. I gave up on it and vented the interior fender wells - using a hole saw:
nick mironov
May 4 2007, 08:22 PM
Added an oil cooler to the engine. I mounted it horizontally on the engine support crossbar and added a scoop to direct the air flow up through it and out the top engine compartment grille:
nick mironov
May 4 2007, 08:24 PM
I changed the Renegade provided rubber hoses for steel pipes, custom bent to the contour of the bottom of the car, and welded hose nozzles on the ends. The return pipe and hoses are 1-1/4" and the supply pipe and hoses are 1" - Renegade recommended sizes:
nick mironov
May 4 2007, 08:29 PM
After lots of body work, and a spray-can prime to stop rust, its off to the painter:
nick mironov
May 4 2007, 08:30 PM
Back from the painter and finally re-assembled:
Paint color is Chrysler PT Cruiser 2005 Electric Blue Pearlcoat
Click here to see interior upgrade using the Auto's International seat and backpad kits...
jimkelly
May 4 2007, 09:02 PM
shit - beautiful paint : )
I took my car today for it's first real tets drive - 202 miles - all seems good.
I can not hear radiator fans too good - would like a light on dash for them.
I wonder if your intake is adequate - not sure if i have seen anyone stick with the 1975/76 front bumper for a v8 conversion ??
Anyway - good luck.
I need to put in a better fuel pump and my hi torque starter when i get a chance.
fwiw - 5th gear at about 28/2900 is 65 mph for me - and i like it - my trans is stock.
under normal driving - i cruse at 3000 rpm - shift at 3500.
2nd gear is good for 0 - 40 but i shift into third before that generally : )
jim
I'd imagine that short stroke 283 twist up pretty quick...huh?
wbergtho
May 4 2007, 09:23 PM
Looks like another nicely done conversion. Good show mate!
Crazyhippy
May 4 2007, 10:11 PM
The front bumper inlet is perfectly fine.
I really like the hole saw radiator exhaust... Very creative and the best of all worlds.
Great color too... I really like your car.
BJH
Dr Evil
May 4 2007, 10:30 PM
Wow, man. Just WOW. Very nice!
Gint
May 9 2007, 08:25 PM
Found it....
That looks great Nick. More pics!
nick mironov
May 10 2007, 12:48 PM
There will be more pictures in a few weeks.
I will also post pictures of the interior upgrade - seats and packpad (using Autos International kits). I am taking the car to Thunderhill for a NASA event on June 2-3. Hope it doesn't break...
Already been to one PCA AX - the car is a handlful. Needs front sway bar, lowering, etc...
Nick
Justinp71
May 10 2007, 01:38 PM
Looks nice... Maybe a 911 front suspension clip would help you out...
Does anyone know the weight of a 914-v8, with the radiator and all that jazz???
Boxer_Twins
Jul 20 2008, 07:28 AM
QUOTE(nick mironov @ Jan 15 2006, 01:28 PM)
Installed. Left side after exhaut installation. Note the rubber bellows at the shifter linkage cover - that is a perfect-fit bellows I picked up at Home Depot for a flexible sink drain:
I went to Home Depot yesterday and couldn't find this bellows. Does anybody have any specific product info on this item like an SKU or stock number or alternate source?
michaelt55
Jul 31 2008, 06:58 PM
QUOTE(Boxer_Twins @ Jul 20 2008, 08:28 AM)
Click to view attachmentGuess I will look tomorrow...
Root_Werks
Aug 1 2008, 09:31 AM
Nice! Can't believe I haven't seen this thread before. Well done conversion.
Wanna9146
Aug 1 2008, 10:09 AM
I know it's too late, but my Pantera has two (relatively small) hood vents that were added after the radiator was upgraded. Original Panteras did not even have these (don't ask me where the hot air went
). The front trunk area is sealed off from the rest of the car with a thick rubber seal (kinda like our rear trunks). You can purchase these grill kits from some of the Pantera aftermarket companies (they ain't cheap, though):
Another view (from another car):
jt914-6
Aug 1 2008, 12:05 PM
What he was talking about with the heat getting into the passnger cabin was the hot air coming out of the louvers flowing toward the windshield and entering the fresh air vent in the middle of the windshield.
Wanna9146
Aug 1 2008, 12:19 PM
QUOTE(jt914-6 @ Aug 1 2008, 10:05 AM)
Click to view attachmentThat intake should close when the A/C is running, right?
The heat inside the Pantera cabin was un-bearable, even with the A/C full blast.
jt914-6
Aug 1 2008, 04:17 PM
As far as I know, fresh air always comes in from there. You can slide the top/air control knob all the way left and close it as much possible. When you slide the red bottom knob to the right air from the heat exchangers is let in. I would say that all 914's with AC was dealer installed and hung under the dash. As said, when using the AC you should have the top knob to the left and the red know to the left too to keep out as much hot air as possible.
3d914
Aug 1 2008, 05:49 PM
IIRC you also have to close the two side vents, as I remember that mine would let warm outside air in even with the controls set for closed venting.
I don't remember ever using the outside air venting. If I wanted outside air I took the top off. For warm/hot air of course one needs the venting from the heat exchangers. I think in my SHO project I'll delete this front outside vent by blocking it off.
Nice project and very well done conversion.
nick mironov
Aug 28 2008, 05:34 PM
See dyno tests added to page 1.
Nick
computers4kids
Aug 29 2008, 08:29 AM
QUOTE(nick mironov @ Aug 28 2008, 04:34 PM)
Nick
Thanks for posting the dyno shots...pretty interesting. It's nice to see what you feel under the pedal in black and white. I am very interested how to go about getting a car on a dyno. Sorry, newbie in this area. As soon as my motor gets broken in I would like to dyno mine as well. First I have to figure out how to find one close to me. Couple quick questions...what does something like this normally cost? How does one know where do you stop for a max rpm...is it a judgement call what you think is a safe max rpm from experience?
Nice ride!
Mark
PS Thanks for the BMW calipers...combined with the performance pads you recommended work great!!
So.Cal.914
Aug 29 2008, 09:22 AM
I googled So Cal Dyno testing...http://www.socaldiablo.com/Intro.html
You will know your redline when you have it dyno'd.
6freak
Aug 29 2008, 09:26 AM
QUOTE(nick mironov @ May 4 2007, 07:30 PM)
Click here to see interior upgrade using the Auto's International seat and backpad kits.......
NICE COLOR ..NICE WORK
fiacra
Mar 28 2024, 05:16 PM
burton73
Mar 28 2024, 06:58 PM
QUOTE(fiacra @ Mar 28 2024, 04:16 PM)
This should get moved to the Cars For sale our brothers may want to buy it for $24,000
very old postings
Best Bob B
Root_Werks
Mar 29 2024, 10:45 AM
Nice to see all these years later the 914 is still on the road being enjoyed.
Steve
Mar 29 2024, 11:33 AM
Nice car!! Good price if their is no body rot.
