Thanks Mike,
I'l post a picture of the set up; I had to go with a different motor/cable set up because of the conflict with the speakers. I think they are AuotoBac. There is no name on the set up but it allowed me to mount the motor at the rear of the door and have a straight run to the winder. I'll shoot a pict of that later today.
Here'a a pict of the two set ups side by side. The only problem I have is the adapter was missing and I'm checking to see if PO may kept it. The adapters from your kit are a hare to big and if I file them down, all the splines are lost. If I can't locate the original adapter, I may JB Weld the adapter to the setup. I believe there will be plently of holding power. Any suggestions will be appreciated.
QUOTE(Dr Evil @ Nov 25 2006, 09:57 AM)
Jim,
I shimmed everything (not the tracks necessarily unless they bind with the new angle) as per Sklines instructions. This keeps the geometry of the window mechanism the same while moving it into the door a slight bit. I do not recall replacing any bolts, but if they are in the way I see no problem with replacing them with a more suitable fastener. For shims I made my own out of some of the spare window adapters. Any nylon stock should work.
