TheCabinetmaker
Sep 21 2003, 05:35 AM
Damn Brad, do you ever sleep? New heads were promised early next week. Here's the list of stuff I think I need. Add to it if I missed anything.
Intake spacers
Exhaust gaskets
push rod tube seals
Mufler gaskets
Should I replace oil cooler seals now?
Everytime I've removed the passenger side head, its been pure hell. The piece of tin next to the oil cooler just won't come off. I figured out that if you put the piston at the top of its travel, the cylinder will slide off with the head far enough to remove everything without losing the rings on the bottom.
Now I want to clean the motor thoroughly. How do keep the water out of the inside? should I wait till heads are back on?
Brad Roberts
Sep 21 2003, 05:40 AM
I'll sleep when I'm dead..
Intake spacers
Exhaust gaskets
push rod tube seals << unless these where leaking or your jacked them up removing the heads... they should be fine
Muffler gaskets
I just remove the cooler. A little more work.. but its either that or bend the piece of tin out of the way.
If the oil cooler isnt leaking from the seals.. leave them.
Dont clean it until the heads are back on and the valve covers are back on.
B
TheCabinetmaker
Sep 21 2003, 05:49 AM
How about I slip the old heads back on to do the cleaning? I have a friend who is chef and brought me a couple of cans of industiral strength oven cleaner.
Brad Roberts
Sep 21 2003, 12:53 PM
You can do that (if you havent already).
The oven cleaner only works if you get the engine hot (so I hear).
B
TheCabinetmaker
Sep 21 2003, 01:04 PM
Looks like it would require the pushrod tubes also. I'll wait till the new heads are back on, clean the shit out of it, then install all the newly painted black engine tin (did that today, looks good). Motor is not too dirty, but the trani is filthy. I used the oven cleaner on the tin and it did a great job.
Talked to Brian Thomas at Rennsport Tulsa this morning(He's more of a friend than just a p mech). He said he's had much trouble with the chinese NPR p&c's. He's had to return 5 of the 6 he has ordered. He said they are piss poor quality. He stocks all the gaskets and stuff I will need.
Brad Roberts
Sep 21 2003, 01:14 PM
Yep. I dont use the NPR's. Havent used them for 8+ years or so. There is a second chinese company that has a very good product. I'll let you know how their 96's work on Monday.
B
TheCabinetmaker
Sep 21 2003, 04:31 PM
Just so you guy's don't think I'm f#$ing off watching the 49er's whip on the Browns while waiting on my heads, here's how I spent my Sunday.
this morning:
TheCabinetmaker
this afternoon:
TheCabinetmaker
oops
seanery
Sep 21 2003, 04:37 PM
sweet!
thesey914
Sep 21 2003, 05:08 PM
-Sweet as
TheCabinetmaker
Sep 21 2003, 05:19 PM
Can't get the headers off the old heads. bolts came off with no prob, but the headers won't budge, I'll put a couple of jamb nuts on the studs and see if I can remove the studs without snaping them, already used plenty of pb blaster, but still hasn't moved yet.
Brad Roberts
Sep 22 2003, 01:47 AM
HUm.. I typically try and remove them while the heads are still on the car. I noticed that you had them still attached in one of the pics.
Did you get them off ??
B
TheCabinetmaker
Sep 22 2003, 04:02 AM
I tried to remove them first but they wouldn't move so I didn't want to screw anything up. Heads, or headers. I'll get them off tonight.
Brad Roberts
Sep 22 2003, 12:51 PM
Your avatar looks COOL. Keep us posted on what is happening.
B
TheCabinetmaker
Sep 22 2003, 06:56 PM
Headers are off. Took some "gentle coaxing" with a brass punch and ballpeen on the studs, but they came off ok. No damage to headers or studs.
Didn't hear from the machinist today, will call him tomorrow. No, I think I'll just drop by to say "high",
and bring him two more heads. Yeh, great excuse.
Brad Roberts
Sep 22 2003, 11:26 PM
Check this out. I'm in the EXACT same position as you (accept I have to drive farther to the event).
I recieved the heads for my wifes car on Saturday after my friend Britain STOOD next to the machinst to make sure the heads got done. Britain brings them up to me.. and the machinist didnt weld/repair/tap one of the exhaust stud holes that was F-ed up. I gave up and took ANOTHER set of 2.0 heads to a machinst closer to me and BEGGED him to have them done this week so I can button her car and drive it for a few days before we leave next Tuesady night.
B
TheCabinetmaker
Sep 23 2003, 06:04 AM
I'll bring a jack, two stands and feeler gauges. You bring the torque wrench. We'll have a head retorque and valve adjust party!!!!! Talk about 914 bonding. LOL.
Can you retorque the heads with the rockers in place? All but one bolt?
TheCabinetmaker
Sep 23 2003, 04:09 PM
Just left the machinist shop. Heads have all the cracks welded up. He said they will be ready by Thursday afternoon
Brad Roberts
Sep 23 2003, 04:49 PM
You cant retorque the heads with the rockers in place.
Which is why ARP and Racware went to a smaller nut on their custom head studs. We drilled small holes in the engine tin to access the top nuts on our race engines and used small plugs to snap into place. It works real good. The smaller nuts allow you to torque all the nuts without removing the rockers.
B
TheCabinetmaker
Sep 23 2003, 06:40 PM
What is the procedure for retorqueing heads and when should it be done? Does it require engine and tin removal?
Brad Roberts
Sep 23 2003, 06:45 PM
I think you will find most people dont retorque them. Its a pain in the ass to remove all the tin and rockers arms. In a perfect world.. we would retorque them. I torque them and let them sit overnight and hit them again the next day.
B
TheCabinetmaker
Sep 23 2003, 06:54 PM
Ok, One more question answered.
Heads should ready Thursday. Gaskets and such should be here tomorrow. Wow, I can't believe this happening so fast. The last time this happened with my 73-1.7, it took 11 months and $2K. This board wasn't around then, but then again, neither was the internet!
Thanks, Curt
Brad Roberts
Sep 24 2003, 01:31 AM
We are neck and neck. My heads should be done on Thursday also. Your 2 hours ahead of me time wise.. we will see who drives their car first !!! Luckily my wifes car is injected and it ran fine before I yanked it apart. It *should* run fine when it goes back together.
B
TheCabinetmaker
Sep 24 2003, 05:17 AM
Mine is injected also, so I don't forsee aproblem there. I suspect yours will run before mine. You have the advantage of experience on your side. Are you replacing the cylinder to case seals? This looks like a slow process. Remove the wrist pin, or recompress the rings?
TheCabinetmaker
Sep 24 2003, 08:26 PM
Not much progress today. Just worked on cleaning the engine bay. Waiting impatiently on heads.
Why do I hate working on cars, but love working on a 914? Adjusted "on rails" valves today. Smooth as silk.
Joseph Mills
Sep 24 2003, 08:52 PM
QUOTE(vsg914 @ Sep 24 2003, 08:26 PM)
Curt,
I feel the same way.....
Brad Roberts
Sep 25 2003, 12:38 AM
No progress on my wifes car.. but I got another one running that was completely apart a few days ago. Its going to the MUSR with me also.
I dont pull the pistons from the barrels... tap the wrist pin out and slide them off the rod. Dont screw up the bushing in the small end of the conn rod. You have to do them in a certain sequence and start from a certain P+C.
B
TheCabinetmaker
Sep 25 2003, 05:56 AM
Ok Brad, what is that sequence and which p/c do you start with?
Thanks for all the info. Keep it coming please.
Curt
TheCabinetmaker
Sep 25 2003, 06:47 AM
Been doing a little looking and pondering while turning the motor over, and here's what I came up with. Start with #1 and 3 at tdc. this will allow the pin's to slide out toward the rear. Then rotate crank 90 degrees to allow access to 2 and 4. Am I anywhere close? Should the pins move freely after the circlip is removed, or will I have to drive it out?
How do you drive it out when it is so close to the other cylinder?
Bleyseng
Sep 25 2003, 08:09 AM
You usually have to tap them out due to oil varnish. Tap lightly! If you can brace something against the rod below the wristpin so you don't muck up anything.
Geoff
TheCabinetmaker
Sep 25 2003, 04:06 PM
Well, the heads weren't done today, but promised for noon tomorrow. Seats and guides are in. Valves in the morning.
Gaskets are in my possesion. Ready to install new jug seals. How about that info on proper sequence? I'm ready to go.
TheCabinetmaker
Sep 25 2003, 06:11 PM
Can't get the wrist pins out. Trying to remove # 1 to the rear. The adjoining cylinder is too close to push it. Am I on the right track?
Brad Roberts
Sep 25 2003, 07:55 PM
Ha ha.. now I'm ahead. I picked mine up at 4pm and had them installed and torqued down by 5PM.
Off to Hooters now for some beer and wings. It will run tomorrow night.
B
TheCabinetmaker
Sep 25 2003, 07:58 PM
I didn't know this was a contest.
TheCabinetmaker
Sep 25 2003, 08:11 PM
QUOTE(Brad Roberts @ Sep 18 2003, 11:52 PM)
You can do this.. and we can help. I can walk you thru a top end rebuild (I'm fresh off of two of them)
So, where's the help? i ask questions, I get haha I'm ahead. How does that help me? Maybe you have something to prove, I just want to do the best I can fo my car.
Brad Roberts
Sep 26 2003, 12:46 AM
Relax.. its not a contest. (It was supposed to motivate you not piss you off..LOL) I'm busy getting two cars ready for this event. One of them I have to drive to the event. I didnt have time to answer you correctly. I was running late and checked the BBS before I left for the dinner.
Now onto your questions.
Yes.. you nailed the sequence.
Sometimes there is a ton of oil buildup around the ends of the wrist pins. This can make it impossible to slide the wrist pin out.
The other thing you can do is heat the pistons.. then they will slide out. A small propane torch can be used to make a few passes past the piston top. Dont hang out with the flame diectly on the center of the piston.. move it around the sides and such. Then quickly.. try and pull the pin out. I use my finger inside the end of the pin. If this doesnt work.. you'll have to pull the barrels off.
Let me know is this helps... feel free to call me. I'm not in front of the computer during the day from noon until 10pm at night.
B
TheCabinetmaker
Sep 26 2003, 06:37 AM
Sorry for my impatience/frustration. I do realize that you are a busy man like the rest of us. I have a biz to run too, so I'm trying to do this at night and on weekends.
I have plenty of motivation already. It's spelled 914!
Heat didn't work. Screwed with one pin for over three hours. Fug it! Pulled the cylinders off of one side this morning. Replaced gaskets and slid them back on. Took ten minutes. I'll do the other side after work today, and be ready for the heads.
I thought you were trailering your cars? That's a hell of a drive for a weekend get together.
I would call only if I absolutely had to, but I don't have the number
seanery
Sep 26 2003, 07:39 AM
He's driving my car!
TheCabinetmaker
Sep 26 2003, 08:37 AM
Sean, I just realized that after rereading your thread on nededing a ride from the airport. Maybe someone could bring your car to the airport?
TheCabinetmaker
Sep 26 2003, 12:37 PM
Yea! the machinist just called to say my heads are ready. Time to rock and roll. Looks like I got a busy weekend ahead of me. Any last minute advice on the install will be greatly appreciated. I have Tom Wilson's book as a guide, but it was written a long time ago I think.
Brad Roberts
Sep 26 2003, 12:48 PM
Slap them on. He who fires the engine last is a rotten egg.. LOL
B
TheCabinetmaker
Sep 26 2003, 12:52 PM
Then I probably stink like eggs already!
TheCabinetmaker
Sep 26 2003, 12:53 PM
Bet I can build a house full of cabinets faster than you!LOL
Brad Roberts
Sep 26 2003, 12:55 PM
See.. now your getting the "jist" of my ribbing. Have fun with it.. it helps me get motivated when somebody says I cant do something or they say they can do something better..blah blah..
Your are 100% correct. I can hang cabinets and do *some* wood working that is about it.. I also know when things should be left the pros.
B
TheCabinetmaker
Sep 26 2003, 01:02 PM
I should probably be leaving this to the pros, but I'm just too damn stubborn.
TheCabinetmaker
Sep 26 2003, 05:06 PM
Woo Hoo, I have heads! cylinder gaskets are on and heads will go on tonight. I"ll work till I can't go any longer, then get back on it in the morning. I rise at 5am daily, so I can't work till 3am like Brad does. I'm old and need my sleep.
Damn the torpedo's, full speed ahead!
TheCabinetmaker
Sep 26 2003, 08:21 PM
Heads are on and torqued. I made a dumb mistake that I'll bet none of you ever made before. I put the heads on and ran thru the first torque sequence when i realized I forgot the two pieces of tin that go on with the heads! Doh! Oh well, nice practice run. Take em back off and do it again. I'll retorque in the morning and continue on. So far so good. I'm ready for that cigar.
seanery
Sep 26 2003, 09:09 PM
WooHoo!!! GOOD JOB!
Brad Roberts
Sep 27 2003, 02:58 AM
Which pieces where you referring too ?? The bottom pieces can go on after they are torqued (did this today).
My wifes car runs nicely. I'm sure yours will also. Once I figured out I crossed the fuel lines where they enter the engine compartment.. hers fired right up without a hitch and idled high on the cold start AAR.
I wont be back online until tomorrow evening. PM Sean or Geoff Bleyseng for my cell number if you need me.
B
