Man, that is a fast car. shake down had a problem, came back and tighten down a oil hose, not bad though.. I will be putting back the passenger seat Monday..
Took it out to cut two access holes, one hole for Alternator Pulley bolt, so I can change the belt later. The other was a 5"x 8" slot behind passenger seat, this will gain access for any distriibutor issues of timing and such. Used the metal cut out's and reinstalled them back where they came from and then sealed with caulking..
WOW... what a car. that S motor really snaps.. pictures later on final stuff
The electrical has not changed yet from what is shown. Volker has something going on and it works great. will advise at a later time..
thanks to you all
Larry
