I want to weld these to the top of the longs.
Also use a matching plate under the car that I can bolt through and weld to the underside.
i don't know exactly what you're describing, but look at JP's pic of his main hoop base plates: that's how i'd do it given that the autopower hoop already has it's own (too small IMHO) mounting plates. also note his plugwelds and perimeter welds. just a warning, it's a bit tricky managing the heat with a mig when welding the plates (thick) to the longs (not so thick).
The tube is 1 3/4" OD and 1/8" wall thickness ( .125" )
cool. thickness is .120 (they don't make .125). total overkill for a full-cage in a 914.
Nate, I would like to get that tube. How long of a piece( s ) do you have?
i'll have to check my pile (later this weekend). i also might have some extra plate for your mounting plates.
