An update:
Progress has been slow, stripped a freebie 914 from a co-worker over a few weeks a month or two back (another shout out of thanks to Rich for helping me with the trailering):
http://www.914world.com/bbs2/index.php?act...=2&t=116222Grabbed some good parts off the car, rubber, interior bits, side shift tranny, etc. Fenders weren't as nice as I had hoped, I will probably have to make two good fenders out of the six that I have, but what can you do.
On my 914, I'm almost in a position to start building up the pass fender and putting it back on. I had to rebuild the fender mounting flange since removing the old fender required some "finesse" to beat the braze job a PO did. Regardless, I wanted to finish up engine compartment work first, which includes putting in a new pass side engine shelf. Started cleaning up that area, and found that what I once thought was a good pass side suspension console is actually very much not:
Looks fine, thought I had dodged a bullet, right?
A little wire-wheeling by the brake hose mounting tab reveled some holes:
So I bit the bullet and ordered new metal. Bummed that I have this additional work, but somewhat glad that this happened. It was always going to be a nagging doubt that my console was rusted from the inside out if I didn't dig in. It was interesting to tap with a hammer on the pass vs the drivers console, the pass side definitely sounded much "tinnier".
I tediously cut off the console support overlays (you can see the rust underneath):
The rust seems to mostly be in the lowest part of the console (makes sense), the ear itself "appears" to be rust free. Now I am just waiting for the time to drill out the rest of the spotwelds and get the new unit in:
Those chunks of metal in the above pic are the cut off support overlays.
-Chris
