could be useful for removing difficult to reach second plug.
Brando
Feb 1 2007, 06:39 PM
Granted how often I change my plugs... About that time the pushrod tube seals would be leaking anyways I would have like 5000 miles to make/break/find a tool that would work. I'm thinking something along the lines of a modified box-end wrench but that's just me.
brer
Feb 1 2007, 07:38 PM
tools are good to keep in the trunk
brer
Feb 1 2007, 08:41 PM
this is the specs from one of the units i've been emailed info on. anyone who understands EFI care to comment?
* 4 ignition outputs requiring EXTERNAL driver * Positive active output * 128 main map sites specifying ignition angle in degrees * 16 Manifold pressure sites * 16 Engine temperature sites * 16 Dwell sites (by RPM) * Ignition fault input from external driver * Total ignition: main map entry in degrees * Manifold pressure entry * Engine temperature entry * Separate CRANK (CB1) and CAM (CB2) inputs * All inputs balanced (floating) for extra noise immunity * Inputs can be configured for un-balanced high threshold level * Missing tooth or CAM cylinder identification * Multiple teeth trigger from 18-60 teeth per turn * Optional Single tooth trigger modes
