QUOTE(Tom_T @ Apr 7 2009, 09:32 PM)
QUOTE(euro911 @ Apr 7 2009, 08:57 PM)
Sorry Tom, I can't provide you with any recommendations for repair facilities.
I typically do my own work, mainly because I don't trust any VW dealership's mechanics any further than I can throw them ... they destroyed my wife's 1999 Beetle before it hit 34k miles.
Except for the injector elbows, all the engine bay's top-side hoses on my wife's 71 appear to have been replaced with 'ribbed' rubber hoses. I'm currently replacing what appear to be the original cloth-covered fuel tank and pump hoses, and installing a new tank screen.
As for a VW dealership providing service for a recall that long ago ... all I can say is good luck. They could probably do it, but I'll bet they'll charge you up the arse.
I'm sure someone from the OC area will pop in and recommend some independent repair shops that can do the job for a reasonable price if you don't plan to do it yourself.
Thanx anyway Ron.
FYI - earlier in this thread someone else had tried to get the Porsche dealership (not VW) in their area to this 914 fuel lines/battery recall for FREE as an ongoing Federal/DOT requirement for any 914 never done.
I was hoping to save some coin by having the dealer do that portion of mine, then I'll have my "regular" mechanic Hans at Hans Imports - who was P-Factory trained on 914s back in the `70s (as well as VW's) - check the dealers work when they change out the other fuel lines not covered.
I could probably do it myself, but am not sure how much I want to tackle on my own with everything else to get this long term storage recovery & body work, & if I did - then I'd have them check my work too.
They've worked on my 914 since I got it in 12/75, & he checked it out & several others before I bought this one. They also have done my 88 Westfalia since new too & all my other cars, and they are a VERY well reputed independent. They do what needs to be done right & stand behind their work, & don't do add-ons to pump up the invoice!
I can highly recommend them if you're ever in need & are anywhere close to Huntington Beach: Hans Imports - 714/960-9000 & 714/536-4000 - ask for Carl or Hans & tell them Tom T. referred you.
Anyway, I'll need to check further on that freebie campaign idea, in order to hopefully offset or reduce some of the significant total costs of getting my `73 2L running again after 24 years stored in my garage!
Best!
Tom
OK - I've partially answered my own question on this recall campaign, by asking at Porsche Cars of North America (1-800-PORSCHE & Option #3), after I was referred there by the gal doing my COA.
As I suspected - they're obligated under Federal Law & DOT Regs. to do it - no matter at what point (talk about open-ended liability!?).
They will still do the Fuel Lines & Battery Cover/Pad Recall Campaign at your local Dealership, & the dealer can contact them &/or the Porsche Warranty Dept. there for the parts, which are supposedly still available.
If you call the number above & provide your VIN, they'll check their records, and if it's never been done on your 914 - then you're IN! They'll assign a case number for your car, and assist with getting it done, if you meet resistance at the dealer.
I cannot yet say whether it will get done, nor if it will be good workmanship. Most of the mechanics at dealers
weren't even born when the 914s were built - let alone work much on them!
So - I'll wait & see.....
Let me know if anyone else has had any success?
