QUOTE(Series9 @ Aug 20 2007, 09:35 AM)
I promise you, that won't be the lesson. That engine alone weighs 175 pounds more than mine. The total installation is at least 250 pounds heavier.
I'd like to know where those numbers come from. I see people throw around numbers like that in nearly every V8 thread. I don't know for sure, but my gut tells me there is no way your 3.6 w/ cooler, tank & lines is 250 lbs less than an aluminium head 350. It's probably less, but not 2-fity. If you can back that position up, I'd like to see it.
The lesson: Power:weight is all that matters. That V8 has to make 100 hp more than mine just to offset its weight.
I've never called bullshit before, but I've gotta do it here. That's some pretty fancy math there. If in order to keep up with your car a V8 has to make up 100 hp to offset that 250 lbs I'm not buying anyway, that means your car must be making 1hp/2.5lbs. So, either your car is making about 880hp, in which case congrats are in order,
or your car weighs about 875 lbs, which is amazing based on the pics I've seen,
or is in order.
Everybody is entitled to their personal opinion on the merits of a particular conversion, but I get tired of the made up numbers to justify the "V8s suck" point of view.
