$5K = no /6 conversion.
Probably not any decent, long lived, conversion of any kind once ancillary equipment (brakes, radiators, clutch, oil coolers, exhaust, gauges, etc.) are factored into total costs.
I did my /6 conversion 20 years ago, performing all the labor myself except for machining.
Here's what it cost 20 years ago(1988):
'73.5 911T 2.4L/6 with 90K miles $2,500.00
Rebuild heads $265.96
911 muffler, stainless steel $free(included with engine)
Muffler tip, chrome $9.57
914-6 engine sheet metal $free(included with engine)
/6 engine mount, Becker Engr. $258.68
Motor mounts, etc. $229.55
oil tank, S.Machining $319.87
914-6 headers $266.56(no heater anymore
Bosche alternator, '73 911 rebuild $117.65
Clutch, '69 911S $340.64
Permatune CD ignition $170.77
Oil cooler, '73 911 $448.06
Tachometer, '73 911 $104.88
Flywheel, '70 914-6 $402.10
Fuel pump, CIS $149.75
Fuel acumulator, '73 911T CIS $52.10
Fuel fitting Zinc plating $10.00
Gaskets, various $31.51
Pressure Fed Chain Tensioner kit $318.40
Sealants $31.51
Misc. nuts/bolts/etc $312.43
Special oil fitting, engine to tank, conn $95.14
Oil lines, etc. $821.18
Engine installed total =
$7406.44Side note #1:
If I had not replaced the /4 engine 20 years ago, I probably would not own a 914 today. The engine I replaced was a 2.0L/4 with carbs installed by PO. Smog illegal then as well as smog illegal today (a '73 914 is test exempt only, but not smog exempt). The fuel injected /6 passes smog easily
, gets better MPG
, and has 50 more HP
Brake/axel upgrade (1991), I supplied all labor:
package deal, used parts $1100
Axels, '73 911S half shafts/CVs
Struts, '73 911S Koni
A Calipers, new F/R rotors, '83 911SC
Stub axels, 914-6
Koni front shock inserts, '73 911 $259.95
Brake pads, front Ferodo $30.19
6x15 Fuchs $500.00
Rear caliper spacer kit $145.64
Tires, Yokahama A008P P195/65x15R $422.00
F/R alignment $140
Alloy lug nuts, alloy hubcaps $122.43
Brakes/wheels/axel total =
$2720.21Side note #2:
I hated the Koni suspension!
Was so stiff I found myself dodging shadows on the pavement! In 1995, I replaced the rear Konis with Bilsteins, and the entire front suspension with one out of a 1989 911 Carrera with Boge inserts. Still very firm suspension, but not jarringly so. Excellent for my street car 914.
Shocks, rear Bilstein $200.12
Front suspension, '89 Carrera $650.00
F/R alignment $140
SwayBar, '89 Carrera underbody $5.00 (a year later, hugh improvement!)
total =
$995.12Dispite the high costs, after 20 years, 200K miles, I am very happy with my engine swap, VERY HAPPY
Very well worth the $$$$$$
