Neal
Jan 21 2004, 10:49 AM
I am starting the process of going Old School with my bumpers. I have a 76 and I am buying a older rear from Kevin this weekend. I have read the posts about this process (not much info) so I am asking if anyone has done this could they give me some tips. I don’t know how much work is involved retrofitting the older bumpers. Any help would be appreciated.
Neal
seanery
Jan 21 2004, 11:42 AM
bleyseng has done it, and robby750's rear has been backdated as well (IIRC).
Neal
Jan 21 2004, 11:59 AM
here's hoping they read the post and reply, to annoint me with bumper knowlege.
AZ914
Jan 21 2004, 01:07 PM
Neal,
I have a big-bumpered 75. I have never done this, but my understanding is that it is not too difficult.
Two things need to be done:
1. Remove the bumper shocks (couple of bolts)
2. Shave the bumper lip retainers. These are tabs that hold the side of the late-style bumpers to the car.
See the pic below...
Neal
Jan 21 2004, 01:12 PM
I thought we had to drill holes for the mounting bolts ?
kafermeister
Jan 21 2004, 01:56 PM
Yes. We do. We also need to find a way to hold up the middle of the rear bumper pad IIRC. ...and the tow-eye bracket from an older car if one chooses to use it.
Rick
'76 914
'75 914
Neal
Jan 21 2004, 02:14 PM
Could you elaborate on that last post, I am looking for info to aid in this task
so more text would be good.
boxstr
Jan 21 2004, 02:44 PM
Neal I have pics of the last retro fit I did to JLO. Email me off line I will attach the pics if you want. I have done four other cars. No pics form them.
CCLINRETROWORLD
RustyWa
Jan 21 2004, 02:47 PM
Why not post the pics here? I'd like to see them also.
boxstr
Jan 21 2004, 03:08 PM
Okay I will post pics here later this afternoon I am heading out for CAMP 914 and a parts run for Mike.
CCLINCAMP914
kafermeister
Jan 21 2004, 03:30 PM
Thanks Craig. I know I didn't start the thread but I'm very interested in your pictures.
Rick
TheCabinetmaker
Jan 21 2004, 04:30 PM
I've been thinking about the very same thing for my 75. I even had the bumper and the shock absorbers off today on the front to see what it would take. I discovered that the mounting holes for the old style bumpers are stamped inside the wheel well, just not drilled. I want to keep my square fogs. I recently upgraded to 100watt halogen bulbs for the fogs and they are awesome. I'm going to incorporate the square fogs in the square openings in the early bumper.
TheCabinetmaker
Jan 21 2004, 05:07 PM
Another thought(I feel like Miles). I was told the rubber bumpers added 200 pounds to the the car. With the front off today, it felt more like 25-30lbs, and the shock absorber felt like 3 lbs. anyone know the real weight? URY?
boxstr
Jan 21 2004, 07:30 PM
Pic 1
boxstr
Jan 21 2004, 07:31 PM
Pic 2
boxstr
Jan 21 2004, 07:32 PM
Pic 3
boxstr
Pic 4
boxstr
Jan 21 2004, 07:33 PM
Pic 5
boxstr
Jan 21 2004, 07:35 PM
Pic 6
boxstr
Jan 21 2004, 07:36 PM
Pic 7
boxstr
Pic 8
boxstr
Jan 21 2004, 07:37 PM
Pic 9
boxstr
Jan 21 2004, 07:38 PM
Pic 10
boxstr
Pic 11
boxstr
Jan 21 2004, 07:39 PM
Pic 12
boxstr
Jan 21 2004, 07:40 PM
Pic 13
boxstr
Jan 21 2004, 07:41 PM
Pic 14
redshift
Jan 21 2004, 07:47 PM
QUOTE(vsg914 @ Jan 21 2004, 06:07 PM)
Another thought (I feel like Miles).
Funny, I do too. What the hell is it with people?
M
boxstr
Jan 21 2004, 07:55 PM
Sorry a couple of pics were out of sequence. One thing you need are the "dogbones" those are the rubber spacers for the front and rear bumpers. These will give you a guide where the holes that you need to drill are going to be located.
Also touchup paint is needed as you can see from the pictures.
After you have the holes drilled, get a longer bolt that will fit in the bumper and use it to hold the bumper(front ) in place while you put in the stock type bolts.
Also get new bolts and washers, I use stainless steel, just because I would prefer them not to rust in place.
Another thing when fitting the bumpers in either the front or rear,. Put tape of some kind on the areas that the bumper may touch and might scratch the body.
In the photos you will see that the front trunk seal needs to have the bodywork bent up to form a channel for the seal.
You do not have to do this , but I don't. Plus I do not glue the front trunk seals in place. You should remove them and clean the channel out, of any glue or dirt or rust, touch up with paint and wax the channel so that fluids do not collect and corrode the bodywork.
Just so you have an idea, the bumpers (triple chrome,filling lic.plate holes),and top rubbers and all hardware, totaled, $1500. on JLO
Any questions I will be happy to answer.
CCLINBUMPERSAREUS
Bleyseng
Jan 21 2004, 08:07 PM
Yep, its pretty easy to do as Craig showed. Fabing the rear rubber support piece takes abit of doing but its not hard.
I have $250 into the used early chrome bumpers,fogs,good rubber tops. Still need to finish the painting as I found some rust under the late bumper covers.
Geoff
RustyWa
Jan 22 2004, 12:18 AM
Very nice photos.
If you are going with the round fogs up front, don't you need to fab a bracket also?
boxstr
Jan 22 2004, 12:37 AM
Round fogs, ahh another problem. I have found a stainless steel nut that I drill a hole in the front area where fog lights mount on the early bumper cars. It has a flange around it with three small holes that I enlarge slightly and then I pop rivet them into place. Takes two, one on each side. The stock allen bolt for the fog lights fits perfect.
I just went out to take a pic of one, I am out. Guess I better figure out where I got those.
CCLINCHOKEFULLONUTZ
Neal
Jan 22 2004, 08:20 AM
Bleyseng, when you say fabbing the rear supports what do you mean ?
Neal
maf914
Jan 22 2004, 08:35 AM
Craig and Geoff,
Thanks for the great photos and info. I have a 76 so I know what its metalwork looks like, but could you explain what is needed to support the early type rubber tops, front and rear? Geoff mentions support pieces. Thanks.
Mike
boxstr
Jan 22 2004, 08:42 AM
Good morning guys, The front bumpers have no real supports like the rear. The rear bumper has a small support that sticks out from the body just above where the lic plate is located. The rear top bumper rubber has a threaded stud sticking out of it that fits into that support. I have not had a problem with the center support not being present on the cars that I have retro fitted. The four bolts that you secure into the chrome bumpers are what hold the bumper on. The center support is only for the top bumper rubber and unless you have one that has no inner steel( you can't see it so don't worry about it) then it will stay in place.
CCLINRETROBUMPERS
kafermeister
Jan 22 2004, 08:54 AM
Thanks for posting the photos. I don't have access to any whole early cars. I found this picture on all914.com. I've circled the bracket.
maf914
Jan 22 2004, 09:34 AM
Now I see.
Thanks Craig and Kafermeister.
Mike
Bleyseng
Jan 22 2004, 09:46 AM
For the early fogs I used a blind nut which is the right size to accept the allen bolt. You drill the hole, in push it in and then tighten it up with this gizmo. I expands and locks into place just like the OEM one except its not welded in place.
Geoff
boxstr
Jan 22 2004, 05:59 PM
Here is a pic of the "tee nuts" that I use for the foglights, along with a new allen allen bolt. You will also wnat to add a flat washer and a lock washer. All items are stainless steel.
CCLINNUTZANDBOLTZ
Gint
Jan 22 2004, 07:46 PM
Geoff
Whaaaa!?!?! Pics please. Thanks Geoff.
Bleyseng
Jan 22 2004, 09:35 PM
Ok, I'll dig them out of the assortment box (pile of shit box) tomorrow.
maf914
Jan 23 2004, 08:03 AM
QUOTE(Gint @ Jan 22 2004, 05:46 PM)
Geoff
Gint,
I think these are also called Riv-Nuts, since they are inserted into a hole and then expand and lock into place when the bolt is screwed in. Sort of like a rivet.
Mike
Bleyseng
Jan 23 2004, 08:29 PM
heres the pieces put together
Bleyseng
Jan 23 2004, 08:30 PM
here is the 3 pieces
Gint
Jan 23 2004, 10:34 PM
Thanks Geoff. I've never seen those before.
Neal
Jan 24 2004, 12:28 AM
Geoff, were do we buy them ?
Neal
Bleyseng
Jan 24 2004, 12:29 AM
I found them at Hardwicks in Seattle but I am sure there must be a online nut and bolt supppy house that sells them.
Geoff
Neal
Jan 26 2004, 09:45 AM
Now that I have the hardware what is the best wat to mark the location of the mounting holes ?. I have a 76
Neal
boxstr
Jan 26 2004, 09:53 AM
Do you have the dogbones?? Those will give you the exact distance between the holes. ( top to bottom).
Look very closely at the area where the bumper holes are going to be drilled. You will find small indentations that are where the holes will go. Put one dogbone in that position and with a thin marker pen make your mark and double check by setting the bumper up to the area.
When you drill the hole, and it you are using bolts, make the holes larger than the bolt, you need a little cheat room to move things around. Take pics and send back and show us your progress.
CCLINBUMPERCARS
Neal
Jan 26 2004, 10:05 AM
Craig, thanks very much for the reply, I do have dog bones and I was going to use studs in the bumpers so all I would have to do is put a washer and locknut on the backside of the stud, that seems like an easier way to hang the bumper.
Do you happen to know how long the factory bumper bolts are ?
Neal
