Been having some serious leaks around the speedo angle drive. Removed it and the housing it fits into from the side of the transaxle to replace the seals. The big O ring around the outside of the housing looks like it will come off and back on with little trouble. How does the inner seal (the speedo drive shaft with the gear on the end goes thru it) come out?????? I thought this would be a simple rubber seal that would just pry out with a screwdriver. No way. Turns out the rubber part (now all cut up) surrounds a steel washer core and this seal looks like it is pressed into the housing. So how do you "unpress" it out? I didnt want to keep prying on it cause I thought it would mess up the inner threads in the housing that the angle drive screws into. Should have just let it leak!!!!
All help and suggestions are appreciated. Thx.
