QUOTE(Chris Hamilton @ Jul 17 2009, 10:13 AM)
Those are the Micro DE HID. Just low beams, but I don't drive at night that much anyways, and where I do, I don't get to use high beams.
These things are brighter than my H4 replacements in the stock doors that I used to use, and they produce less glare to drive past. It's a great combo. I just need to get some clear lenses to put on there and a full coverage hood from sheridan.
I also had to use dual 3W yellow LEDs below each one for enough brightness on the turn signals.
So pretty much the same thing just you have the HID kit. I wanted to at least attempt to get a H4 hid bulb in a Micro DE case down the road. I just don't know how well those moving bulbs are going to create the cut off.
The micro DE does have a built in cutoff. It is probably possible to position the moving HID buld so that in the normal position it would use the bulbs own cuttoff and then move forward past the cuttoff to give the brights.
I am less then impressed with pretty much every HID kit I have seen to be honest. But the DE cases I can get for around $120 and a kit fo around $175. If I can get it to work that would be great. If not then I won't have wasted $600.
Thankfully Chris did all the hard stuff.
