malaga_red75
Jul 9 2008, 01:35 AM
Well, I thought this would never happen, but she went up on the stands tonight.
-this may be a slower progress thread as I work and have practice till 8pm everday except friday. But, it will get done!!!!
Here are some pictures for now.
rick 918-S
Jul 9 2008, 07:56 AM
malaga_red75
Jul 16 2008, 09:46 PM
So i have removed everything to drop the engine except the CV's.
I know I need a special 12 point start tool. What size is it? and does anyone have any good places to get one. Checked kragen already, and they didnt have any 12 point tools.
Also, i am trying to get the passenger seat out and it wont budge. The PO had the seats re-upholstered but upon re-installation the PO put the driver's seat on the passenger side and the passenger seat on the drivers side. The passenger seat is completely jammed and doesnt slide foward or back and only tilts in its current position. because it wont slide foward I cant access the 4 bolts that attach the seat bracket to the car. any ideas??
-Peter
pankopp
Jul 18 2008, 08:20 AM
good luck with the whole coversion, I have the ej-22 motor in my '70 914 and it is a blast! try using a long flat blade screw driver to wedge in between the seat lock and the rail and the passenger seat should slide forward. Thats what i have to do...
ArtechnikA
Jul 18 2008, 12:27 PM
QUOTE(malaga_red75 @ Jul 16 2008, 11:46 PM)
I know I need a special 12 point star tool. What size is it? and does anyone have any good places to get one.
Hazet is probably the best; PerfProd and the usual suspects will have them.
MetalNerd
[ MetalNerd Site ] also has good 12-point stuff. 8mm. Not really "12-point" they're 'triple-square' ...
But any NAPA store will probably have them - look on the pegboard of KD tools. You may find a version that you slip into an 8mm socket, in which case, get a good 6-point 8mm socket too.
sk8kat1
Jul 18 2008, 12:29 PM
QUOTE(ArtechnikA @ Jul 18 2008, 10:27 AM)
MetalNerd
hey we can't leave our friends at P-parts off the list of a source of that tool either ...or a friendly local teener owner might let you just borrow it
malaga_red75
Jul 20 2008, 01:35 AM
QUOTE(sk8kat1 @ Jul 18 2008, 11:29 AM)
MetalNerd
True....anyone close to Menlo Park, CA that wants to let me borrow the CV tool for an afternoon?
-Peter
LvSteveH
Jul 20 2008, 12:50 PM
QUOTE(malaga_red75 @ Jul 20 2008, 12:35 AM)
-Peter
Many auto parts stores actually carry the 12pts
malaga_red75
Jul 20 2008, 01:28 PM
QUOTE(LvSteveH @ Jul 20 2008, 11:50 AM)
-Peter
I just bought the tool online last night on metalnerd.com now back to the car to get that damn seat out!!
-Peter
TonyAKAVW
Jul 21 2008, 04:34 PM
Good luck with the conversion!!
-Tony
malaga_red75
Jul 23 2008, 09:08 PM
QUOTE(TonyAKAVW @ Jul 21 2008, 03:34 PM)
-Tony
Thanks tony!
-I got the motor today, i will post pics a little later
...and I got the seat out.
-Peter
atomix8
Jul 24 2008, 07:48 PM
Any secrets on the seat (PB Blaster, etc), or did you just tug like hell?
jimkelly
Jul 24 2008, 09:03 PM
i have a v8 914 but with gas prices today - i am thinking it would be nice to put together a 1.8L or slightly better subaru conversion with radiator in engine bay, ducting air thru the passenger door and thru firewall. maybe no pass seat at all?
malaga_red75
Jul 25 2008, 11:22 PM
QUOTE(atomix8 @ Jul 24 2008, 06:48 PM)
luckily I was able to remove the seat with the intention of putting in racing seats. But what I did was I removed the upholstery and the foam and then I drilled out the retaining nuts for the seat mount. My goal was to preserve the floor brackets I'll post pics later
malaga_red75
Jul 26 2008, 02:40 AM
QUOTE(jimkelly @ Jul 24 2008, 08:03 PM)
My car currently has a strong running 1.8L. (drove it home from Sacramento to Menlo Park..bout 3 hours... 75 the whole way no problems, and I also drove it pretty hard before it went on jackstands and it never hesitated or hick-up'd) It will be for sale...PM me if your interested
malaga_red75
Jul 26 2008, 02:42 AM
Stripped interior---drilling out the nuts
malaga_red75
Jul 26 2008, 02:43 AM
woops...
malaga_red75
Jul 26 2008, 02:45 AM
i am forever in debt to my parents for letting me takeover the garage...
malaga_red75
Jul 26 2008, 09:27 PM
Engine is out! will post pics later
-peter
malaga_red75
Jul 28 2008, 01:43 AM
So, updates for the weekend
-the engine is out!!!! my brother and my two friends came over to help with the removal. all went well. got a little hung up on some of the engine tin, but easily fixed with a little massaging of the tin.
-removed the rest of the floor tar, so now the entire floor and backpad is ready to be sanded/grinded down to bare metal then I will por-15 the entire inside.
here are some pics...
malaga_red75
Jul 28 2008, 01:44 AM
coming out...
malaga_red75
malaga_red75
Jul 28 2008, 01:45 AM
malaga_red75
Aug 8 2008, 11:49 PM
Alright,
So here is what I have been up too. I started the process of grinding down all the rust and paint on the floor pans and firewall to find out exactly what is good metal and what will need to be replaced.
I took a quick brake of grinding and took about two days to re-fresh the gauge panel and the gauge bezels. I sanded them down to metal, primed, painted and clear coated.
I am almost done with the sanding/grinding of the paint and other 'stuff' that has accumulated on the car. After I am done it will get some POR-15....yeah baby!!!
I also got some more parts. I got the engine mounts from small car, the radiator (from a late 80's jetta, the same one that tonyakavw used in his second radiator setup). I also got a 16 gallon air compressor with a max 150psi from my friend who bought it for a fence he built and now has no use for it, so it is mine until further notice....hurray!!!!!!!!
So, I do have a few questions and then I will post pics.
-Can the POR-15 go directly onto the bare metal or do I need to add a coat of primer first??
-What type of sealer should I use to re-seal all of the joints where the previous white gooey material was or will the POR-15 be enough?
That is all for now, I know I will think of more questions as soon as I finish posting.
-Peter
pics to follow...
malaga_red75
Aug 8 2008, 11:50 PM
down to metal
malaga_red75
Aug 8 2008, 11:51 PM
malaga_red75
Aug 8 2008, 11:52 PM
primed, painted, baking
malaga_red75
Aug 8 2008, 11:53 PM
malaga_red75
Aug 8 2008, 11:54 PM
malaga_red75
DONE!!!!
malaga_red75
Aug 8 2008, 11:56 PM
Metal...lots o metal......and some rust
malaga_red75
Aug 8 2008, 11:57 PM
malaga_red75
Aug 8 2008, 11:58 PM
rust....
malaga_red75
Aug 9 2008, 12:01 AM
The tools I am using...
Various sizes of wire brush (crimped) wheels
2 paint/rust remover wheels
that big one is called a removal all brush or something like that...worked really well to get the first layer of bulky rust off
small grinding wheels, a couple different styles, VERY useful for getting the tiny joints and areas where the wheels couldnt get too.
G e o r g e
Aug 9 2008, 11:43 AM
nice job keep it up
malaga_red75
Oct 9 2008, 09:58 PM
So, nothing has really changed on the car since my last post since I have been away at school, I have had no chance to work on the car. However, I have been ordering parts for a while and was able to make it home last weekend between water polo games and look at my new parts, and yes I took pictures. So here ya go......
--Stage one clutch kit from KEP--
--Flywheel from KEP--
--Adapter plate from KEP--
malaga_red75
Oct 9 2008, 10:00 PM
--radiator--
--fans--
--parts porn--
-Peter
malaga_red75
Oct 9 2008, 10:01 PM
TonyAKAVW
Oct 10 2008, 04:58 PM
Excellent choice on the raditor
And those fans look familar too. Those tools you are using for paint removal are identical to the ones I used. I'm actually amazed, you have literally the exact number and variety of tools as I do (except the small grinding stone bits).
Looking good!
-Tony
malaga_red75
Oct 10 2008, 05:56 PM
QUOTE(TonyAKAVW @ Oct 10 2008, 03:58 PM)
Looking good!
-Tony
Thanks tony, yea the small bits werent as useful as i thought but did help with some of the small corner style areas. I have a question for you actually. Where did you get your expansion tank and what style did you get?
malaga_red75
Dec 1 2008, 12:02 AM
Hi,
updates:
The car has been to the body shop and back in a record 2 weeks for the hell hole repair work (it always helps when your mom went to high school with the body shop owner).
While it was in the body shop and while I was home on thanksgiving break, I did some work on the subaru engine. I took off the wiring harness and the power steering pump and the A/C pump. I also removed the intake and the alternator. I put on the KEP adapter plate and flywheel/clutch assembly. I mated up the tranny and just snugged down the nuts cause I am going to send the tranny out soon for a rebuild....Dr. Evil?
Anyways....My question is this:
When the tranny and engine are mated up, the clutch fork has way too much 'slop' before the clutch begins to engage. I then realized that this might be caused by the thickness of the adapter plate pushing the transmission out further than it used to be. So, do I have to compensate for the width of the adapter plate? Thanks in advance.
-Peter
TonyAKAVW
Dec 1 2008, 01:21 PM
I got my expansion tank from a local place (which has a web site) www.importedcarparts.com. Anyway, its the expansion tank from many late model Audi and VW cars. Its nothing special, just cheap. I think it was $15 or so.
-Tony
malaga_red75
Dec 1 2008, 04:53 PM
Thanks Tony!
Anyone have an answer for compensating for the width of the adaptor plate?
TonyAKAVW
Dec 4 2008, 04:10 PM
The custom flywheel should compensate for this. I had no problems when putting my clutch in. I already had the adapter plate, so I ordered a flywheel and clutch kit from Kennedy and had no fit problems etc. That was perhaps the smoothest part of the conversion actually. Make sure you have all new parts in there including the bushing for the fork, etc.
-Tony
malaga_red75
Dec 5 2008, 02:08 AM
Thanks Tony, I will not be at home for another two weeks...school....but when I get a chance I will replace the fork bushings...etc. and re-check my install.
Until then...studying for finals....I wonder sometimes why I am a CE major and not ME...seems more appropriate for my hobbies...
malaga_red75
Jan 17 2009, 06:03 PM
Hey guys,
Sorry I haven't posted in a while, I have been on my vacation and...well been vacating. haha!
Anyways, I have some things to post about the car so here we go-
-I tackled the radiator shroud and finished it. This was the biggest ???? for me and I am glad that I was able to do it. It was my first time working with sheet metal, so it isn't pretty but I think it will do the job.
-My uncle came over yesterday and today and welded in my floorpan, seat brackets, and tacked in place my engine mount for the subaru engine. He is now going to take the seat mount to his work and use the bigger 220 (we only had a 110) to weld it together. He did an amazing job and I don't know where I would be without his help thus far.
Next---
well, I am heading back to school in a few days and wont be able to work on the car for about a month but here is what will be next eventually.
-now that interior is done, paint with por-15
-paint front trunk with por-15
-run radiator lines (on the way from renegade) and install expansion tank
-hook up electrical and put the intake and alternator back on and then install the engine
that's the line-up for now. let me know what you think and oh yea....PICTURES!!! (and i have a clip of my uncle laying down a weld, but I'm not sure how to get that on here...youtube and then post link??)
First...test fitting and making panels
Click to view attachment more.
malaga_red75
Jan 17 2009, 06:06 PM
Painted and finished
Click to view attachmentSeat bracket...spot welds drilled out...conveniently making holes for plug welds
malaga_red75
Jan 17 2009, 06:08 PM
malaga_red75
Jan 17 2009, 06:13 PM
jimkelly
Jan 18 2009, 10:47 AM
man - u should have been a plastic surgeon - that floor pan/ seat bracket weld job looks great! jim
