QUOTE(abnrdo @ Apr 12 2011, 08:54 AM)
Gorgeous car!! Great attention to detail. So much so that I must know how you ran your oil cooler lines. I notice they disappear under the gas tank. How do they transition to the back of the car? Are they in the tunnel?
Thanks,
Jim
Jim, I took some pics, here you go:
Front two holes in bulkhead. The oil lines easily run under the tank and up the side, there is a pretty good gap between the tank that the chasis near the corner of the tank
Click to view attachmentArea where lines enter outer front wheel well:
Click to view attachmentThis pic isn't all that great but if you look close you can see the lines running up against the wheel well, there are no clearance issues here as long as you keep the lines tight up against the wheel well:
Click to view attachmentThis pic shows the oil lines coming out of the space between the longs and the rocker panels. Although they look low here, they are actually 3/4 higher than the lowest point of the car on that side (wouldn't want to have these bust if you bottom out the car):
