McMark
Oct 17 2009, 11:09 PM
Amazing job.
I would do charcoal/gray on the wheels before I did black, if it were my car.
pete-stevers
Oct 19 2009, 12:32 AM
you could do something different for the wheels, like an accent color or an complete opposite color ...if you are daring,
Gint
Oct 19 2009, 08:02 AM
Just swipe the wheels off Thomas's car. They should be a pretty close match!
Looks awesome.
proto31
Oct 22 2009, 12:14 PM
Swiping Thomas' wheels would be the easiest route, not a bad idea...
I like the idea of the dark gray, do you guys have any pictures of any green cars with gray fuchs? I've never been the biggest fan of painting a set of fuchs all the same color without having the lip and spokes anodized clear, but I think it's growing on me. All the trim on this car will be powder coated in matte black, I really like the contrast between the black and green. Any pics would be helpful.
Also, I started assembly of the 3.0 last night, I'll post some pics a bit later. Other updates: completed new brake hard line install in the rear half of the car, received Cohline oil line from Rebel Racing (this stuff is REALLY nice, same as factory original lines, and reasonably priced), finished the hard oil lines that run to the front oil cooler, installed the dash frame with new vinyl and hooked up the fresh air box, also bought a bunch of new parts and found some really cool NOS parts at the Pomona swap meet last weekend.
Dan
proto31
Oct 22 2009, 11:08 PM
Here's some pics of the beginning of the engine build:
Parts and assembled crank-
Click to view attachmentCase-
Click to view attachmentClick to view attachment
proto31
Oct 22 2009, 11:10 PM
The carbs, completely rebuilt, ultrasonically cleaned-
proto31
Oct 22 2009, 11:15 PM
Rear brake hard lines, with T instead of proportioning valve-
Click to view attachmentUpper dash frame-
Click to view attachmentFront oil cooler test fitting-
proto31
Oct 22 2009, 11:18 PM
proto31
Oct 22 2009, 11:28 PM
I got my oil line from Rebel Racing, they are original wrapped Cohline, you give them a rough estimate of the total footage and the type of fittings needed, they send you the complete line with fittings, you cut and fit everything how you like and send them back marked, they crimp all the fitting and send it back to you. Custom oil lines that will last forever and look factory, very reasonably priced.-
Click to view attachmentClose up-
Click to view attachmentFittings-
proto31
Oct 22 2009, 11:35 PM
Here's some previews of the front and rear suspension, real 935 front struts, coil overs with needle bearings (Rebel Racing again)-
Click to view attachmentClose up of upper bearing-
Click to view attachmentRear coil overs-
proto31
Oct 22 2009, 11:39 PM
Front rotor (picture of just one)-
Click to view attachmentMisc. Cool find at the Pamona swap meet last weekend, NOS front trunk pull with key, I've never seen a new one of these before-
cwpeden
Oct 23 2009, 03:11 AM
It may have already been mentioned, but I think your rear sway bar is upside down. Had mine the same and it hit the cross member right where it takes the bend down.
bcheney
Oct 23 2009, 05:50 AM
You are doing a VERY nice job with all your work. I am converting my 75 to a six and fully appreciate the time and dedication that it takes to jump into a project like this. You will have one helluva a ride! Keep the pics coming!!
TravisNeff
Nov 26 2009, 10:40 PM
Bada-bump!
Dr Evil
Nov 26 2009, 10:47 PM
Thanks for the oil hose info. Great build
ajserrano
Jan 16 2010, 12:10 PM
QUOTE(proto31 @ Oct 5 2008, 08:29 PM)
Here are some photos from Armando Serano's website, this is supposedly an exact replica of how the factory did it. I've seen pictures of GT front trunks with the same cover over the area where I've welded in the bar, but unfortunatly you cannot see what's underneath the cover.
...precisely the idea...CLARIFICATION...The Porsche factory never implemented this front-end modification on any 914-6 GT and I can't take credit for it either. This modification was initially fabricated and implemented in a very early IMSA 914-6 by the very talented Don Araki. I was told Araki built a winning GTU 914-6 race car for Wayne Baker many years ago. To see additional photos of the 914-6 to GT conversion that Mr. Don Araki created along with the owner, Dr. Bob Gagnon, please follow these links;
http://www.pbase.com/9146gt/other_porsche_...9_dr_bob_gagnon http://www.pbase.com/9146gt/image/22288815http://www.pbase.com/9146gt/image/22288814We kicked-it up a notch...Because this was NOT a Porsche factory GT modification, we simply decided to cover the modification work in a way that could not be seen and later scrutinized as a "non-factory 914-6 GT" mod.
Frankly, it was a brilliant modification and IMHO, certainly worth the effort when considering its benefits while cutting out those two large gaping holes at the front trunk of the 914-6 to accomodate the large BEHR front oil-cooler. To see our entire fabrication sequence, follow the link below;
http://www.pbase.com/9146gt/the9146gt_fron..._reinforcements
geniusanthony
Jan 17 2010, 12:09 AM
I just went through your thread and I am impressed with the job you've done. Makes me want to take mine apart and redo everything.
That front end support looks great and def. beats just putting a fiberglass cover on the floor next to the giant hole for a cooler.
proto31
Apr 5 2010, 04:05 PM
So, a lot of progress has been made since my last post. I got a bit lazy posting stuff, I enjoy reading other peoples posts more than creating my own
. Thomas, Alberto and I got the engine in a few months ago, all the suspension is on, electrical is working great and the paint is complete! Andy stopped by this Saturday and helped (did all the work) buff, polish and pink out the paint after I had color sanded it. It looks AMAZING!!! Thanks Andy!
Here some pics, in no particular order:
Click to view attachmentClick to view attachmentColor Sanded:
proto31
Apr 5 2010, 04:12 PM
Engine installed:
Click to view attachmentFront S Calipers, Thomas and I each had a set polished and re-anodized, new SS pistons and SS cross-over tubes:
Click to view attachmentShot with Thomas created sway bar arm (red anodized):
Click to view attachmentRebuilt CV drive shafts:
proto31
Apr 5 2010, 04:28 PM
Thomas' sway bar arms, pre-annodizing. These mount onto a hollow 23mm Tarret bar:
Click to view attachmentUnderside, new 19 mm MC, rebuilt steering rack and aluminum cross member:
Click to view attachmentI'll be running 15 x 8 inch Fuchs all around, I had these stripped, then put them on a lathe to polish them and then had them anodized with a clear finish in a way that replicates the RSR finish pretty closely. I will paint the centers, you'll have to wait until the 25th to see what color. My plan is to drive this thing up to Ron's swap meet on the 25. Here's a pic after the anodizing:
AgPete139
Nov 9 2010, 03:20 PM
Any updates?
proto31
Feb 27 2011, 11:51 PM
QUOTE(AgPete139 @ Nov 9 2010, 01:20 PM)
Any updates?
A few updates, I've already put 2,400 miles on the car, it's a blast to drive. I recently picked up a factory NOS brown carpet set that I will be installing in the car, the original carpet was brown, I'm going to change the door panels and re-do the seats. I also decided to put some of the factory style sound deadening tar on the floor boards, really cool stuff. You cut out a template, and form it into place with a heat gun. Here's some pics:
proto31
Feb 27 2011, 11:54 PM
proto31
Feb 27 2011, 11:56 PM
AZ914
Feb 28 2011, 07:53 AM
Root_Werks
Feb 28 2011, 12:04 PM
Man that looks great!
proto31
Feb 28 2011, 04:53 PM
Thanks! It's been a lot of fun so far. Any ideas on door panel and seat colors/fabric? I've got that NOS brown carpet set and am going to have the door panels and Scheel seats re-upholstered. Before the brown, I was going to do the Scheel seats in black german vinyl sides with houndstooth centers. Now I need to do the door panels brown and think I'll probably have to go brown with the seats as well, any thoughts? Anyone have any pics of nice brown interiors?
Thanks,
Dan
Ferg
Feb 28 2011, 05:23 PM
I vote for brown/brown hounds tooth, or brown with a tartan center.
Check out www.autobahninteriors.com for a bunch of pics...
Ferg
MDG
Feb 28 2011, 05:47 PM
QUOTE(Ferg @ Feb 28 2011, 06:23 PM)
Ferg
+1
Would look amazing with the green and give it a major period feel. I believe T.C. is doing the black houndstooth in his and the seats he had done are beautiful.
proto31
Mar 4 2011, 11:22 PM
I made a shroud for the front oil cooler, I've been meaning to do this for some time. I took some 1/16 aluminum and formed it, riveting the side panels on. Then covered it in perloin. Also removed both seats, they'll be on their way to the upholstery shop on Monday. Last thing I completed this week was the harness bar, I ended up welding some 1/8 steel tabs on so that I can connect the harness to the bar without having to drill holes in the firewall.
Click to view attachmentClick to view attachmentClick to view attachment
proto31
Mar 4 2011, 11:25 PM
speed metal army
Mar 4 2011, 11:56 PM
Kickass.
Ive decided to stash $1000 bux every month,for when you get bored of this thing.Dibs!
I love it.
proto31
Mar 6 2011, 12:14 AM
Thanks man, I've had a lot of fun building it so far...
proto31
Mar 7 2011, 05:02 PM
Dropped the seats, door panels and center armrest off at the upholstery shop today, they now sit at the same shop that did Andy's (Socal Andy) seats. I'm going with Cork (original Porsche color) and brown hounds tooth (they had some really nice, tightly woven stuff). It's going to be a lot of brown, but I think it will work. It's going to be tight for Route 66, may just have the seats back then, we'll see. Now I'm working on fabricating some stainless steel brackets for my 6" Marchal fog lights. Turning out pretty good so far, welding stainless is a little different than standard steel. I'll post some pics in a little while.
Ferg
Mar 7 2011, 05:13 PM
QUOTE(proto31 @ Mar 7 2011, 04:02 PM)
I've got Cork in my 75 Carrera
Eric_Shea
Mar 7 2011, 05:16 PM
Dibs!
He just sold it to me.
Ferg
Mar 7 2011, 05:28 PM
QUOTE(Eric_Shea @ Mar 7 2011, 04:16 PM)
Dibs!
Get in line...
QUOTE(proto31 @ Mar 7 2011, 06:02 PM)
That is going to look spectacular!
proto31
Mar 7 2011, 11:45 PM
I found some really nice (as close to NOS as you can get) sun visors at the German swap meet this weekend:
Click to view attachmentThe NOS Marchal fog lights/driving lights, I also picked up some covers for them at the lit show over the weekend:
proto31
Mar 7 2011, 11:48 PM
Some more:
Click to view attachmentInstalled without bumper, stainless brackets go through the stock fog light grills:
proto31
Mar 20 2011, 09:02 PM
Some updates, Socal Andy came down and polished my conversion, Thomas' new (new to him) boxster, my boxster and his 914, a fun day. Some pics:
proto31
Mar 20 2011, 09:04 PM
Thomas' car, a really nice 97' with a GT3 front bumper, he's taking it back to Germany with him. If you look carefully, you should be able to see 4 Porsches in the first pic, my neighbors thought I was running a chop shop in my garage for stolen cars, pretty funny.
proto31
Mar 20 2011, 09:08 PM
Received all the interior pieces, seats and door panels turned out great, I like the color a lot. Really looks sharp in the daylight:
Click to view attachmentClick to view attachmentInstalled the vinyl strips that lay on the cross bars:
dw914er
Mar 20 2011, 09:10 PM
wow!!!!!!!!!!!!
that car looks stunning. The green and that fuchs finish goes great together.
proto31
Mar 20 2011, 09:14 PM
Installed all the carpet, had to remove the steering column so that I didn't have to cut a slit in the carpet set, PITA
Click to view attachmentPassenger door before new panel
Click to view attachmentand after:
proto31
Mar 20 2011, 09:17 PM
Thanks for the comments!
Here's the interior after I finished this weekend, still need speaker grills (although I won't be installing a radio):
Lou W
Mar 20 2011, 09:51 PM
Gint
Mar 21 2011, 05:41 AM
I hope you make it. I'd like to see that car in person. Very nice!
Ferg
Mar 21 2011, 08:16 AM
Wow
Eric_Shea
Mar 21 2011, 08:48 AM
Isn't this car already done?
I thought we saw it last May at WCR in Tahoe...
