Getting closer to paint time. Most importantly, I finished lengthening the frame on my Ford F150 tow vehicle and got it running again with the long bed.
On the 914 front, I pulled the dash out and have been welding holes up left and right.
Sidemarkers are gone.
Antenna is gone.
Extra holes from some DAPO stereo install gone.
Extra holes from some DAPO side mirror install gone.
Pulled off the rockers and everything looks as good as the rest of the car. A little surface rust that will clean up with a wire wheel. And the rockers themselves are solid.
There was a bit of body damage around the PS turn signal which I straightened after welding the sidemarker holes.
I'm thinking about pulling the suspension off as well since it's already pretty well stripped down. Not sure if it was actually benefit anything though. I'm sure it would make me clean and powdercoat all that stuff as well.
Probably should, since I'm already that close. But then again, I've already got a huge list of stuff to do.
Opinions?
