I haven't measured it but if the holes are 2/3mm that space inbetween them seems to be more than that like maybe the 1mm Reid posted.
Ok I couldn't stand it I measured my 75 and also discovered a couple of variances. The 4 in my build date has the bottom hole missing and the beginning # symbol has a left beginning bottom horizontal line hole missing. I guess the punches got stuck.
Also posted above: The diagonal line has different spacing than the numbers.
On both the 914 and a 72 bug the 4 is different between the date and vin. The top left leg on the 914 date (11/74) has 3 holes down and the vin has 4 holes down. All the 7's are the same.
The measurements seem to be:
height of the char. .278-.280
width .172- .175
vin width 2.550- gap to rt edge .297- between the date and vin .420
date width .980- gap to rt edge .297- down from top .232- vin and bottom .320
This was with calipers holding over the tracing so it could be a little off but not much.
It's almost as if the safety stickers were hand punched.
I don't know if it will help but I did a pencil tracing on both stickers. I can mail them if you want.
No offense man, but if you're going to stand up and say that I'm wrong you might want to take a closer look at the numbers I posted. Also, as has already been noted in this thread the later stickers are different from the early ones, and the 4-cyl versions are different from the 6s...which is what T.C.'s got.
Reid
disclaimer: didn't get shit for sleep last night, so perhaps a bit
I truly appreciate everybody's response and willingness to help. Please no dis-record between brothers on my account. I'd hate to take out the switch and take you to the time-out house
T.C.
