QUOTE(Racer @ Mar 21 2009, 04:44 PM)
If you included pics, it would have been the "posterchild" for first posts
OKAY - So just to make you happy, last week I spent 20+ hours digging the crap out from on & around the 914, crawled over, under, in, around & through taking pix & assessing the work ahead - literally through, as the pass door is inop. & there's only about 12" clear on driver's side, so I used a broom to crank down the window & slithered in! Since this post process limits pix to 500kb & my camera took 1-2+ MB pix, I've had to crop down a few to give you the general idea of what I'm up against.
Hopefully you can then all weigh in on whether to fix or cut-&-weld-in "new" parts (probably from a donor junker 914)????During that grueling overnight process, I also pulled off the front bumper/etc., grills, horns, valence, turn & marker lights (for safe-keeping ya know!), etc. In that process, I found the fog lights' wires just snipped off behind the dual tone horns (verified that: 375 & 400 MHz), and the mounting bolt receivers were hiding behind the tweaked bumper et al. Of course I've always seen the perfect hole in the dash & basketweave cover material where the switch once was!
I also found the center console's front & rear mounting brackets' holes under the dash & in front of the storage console/flip-up pcenter pad; & the wiring harness connectors under the tunnel carpeting - so apparently it was once there - pretty sure to positive also! Why it was removed??? ....maybe for more leg room, especially if the center flip-up cushion was often used for a 3rd passenger??
No idea on why the Rivieras instead of 2.0 Fuchs, unless it had to do with one of the speculations that either I or your responses posed. Another new speculation I have come up with in researching 914 recalls, is that there was a Porsche Recall regarding the Alloys being improperly installed, and maybe the Dealer took the easy out & just installed VW Rivieras instead of correcting the front hubs/rotors???? I'll have to pull the RF Riv & compare the Rotor on there with the new ones I just got, to see if it has that little centering bump-out thingy!? ...real technical I know, but I'm brain-dead about now I can't think of the name of it!
Wouldn't it be a hoot if I could force a dealer to correct that & do the proper rotors, hubs and go find & buy me some nice 2.0 Fuchs Alloys ALL AT THEIR / PORSCHE'S COST!? ...I know, I'm dreamin'!!!
However, along those lines, I had the COA gal refer my query about whether Porsche would still do the Fule Lines & Battery Recall Campaign on mine (to at least save me some of the cost to replace the old OEM lines). And they do and I even got an "official Porsche Case Number" to get it done at a dealer whenever I'm ready can get the 914 to them. Then they have to find somebody who knows how to work on a 914
(since the car is probably older than most of their mechanics today) & run down the parts! They apparently have to honor all uncompleted recalls!
But first, an update on the "History Quest"! The COA is on the way, which actually prompted my picture quest 'cuz they needed a pic of my GA engine number before they would list it as a 2.0!
Furthermore, I've tried to read the trunk chassis number stamp which is very faint after OE + 3 Repaints, and with the limited clearance at the driver-side door, I can't even see the front label, the rear jamb lable & the one on the Pass-headlite box were painted over & unreadable -
ANY IDEAS ON HOW TO CLEAN OF THE PAINT WITHOUT DAMAGING THE LABEL???? I also verified Sway Bars F&R, and the "Red" Konis went on the rear - not front struts as I'd said before (that was only a fix for one upper F strut mount, per the service record). I know that my mechanic told me they were Bilsteins before, but back then the replacement OEM Bilsteins were 2x the Konis, and cash was tight then - so I went with Konis!? I haven't tried to look in to see the F strut inserts, but the struts appear to be black or dark grey where I wiped off the grime, which I think means their Boge Struts - yes / no?? So I feel that verifies the Performance Group Package was there "standard"
And I verified dual tone horns, I know I have the intermittent wipers 'cuz I've used them!; verified the center console/gauges were most probably there at one time, she has the mouse-fur targa top headliner & "textured" black finish on it outside, has the vinyl roll bar trim & chrome F&R bumpers, has the tan/"carmel" loop/pile OEM carpet & Tan/"Cinnamon" Leatherette/Basketweave upholstery, padded Leather(ette) covered Steering Wheel & Shifter Knob (with the "old colors" cloisonne Porsche badge), & leather(ette) shifter boot - all confirmed & per the pix.
So that all sounds like the "fully loaded" 914-2.0 / "914S" upgraded equipment, as described in the early 1973 Porsche 914 full 9 page marketing brochure which I recently acquired on=line from Bishko for this very purpose. Therefore, I feel fairly confident & comfortable in restoring my early 914-2.0/914S with all of the currently "missing" 2.0 AG/PG items: restoring the missing fog lights/chrome grills, center console/3 gauges, & 4 Fuchs 2.0 Alloys.
...or would it have come with 5 Alloys - including the spare???? (FYI - my spare in the pix is the "then new" for 73 steel wheel with the cross-pattern stamped design)
However, during several phone & e-mail conversations over the past 2 weeks with Kristen doing my COA at PCNA, I now know the following:
VIN 4732901954
Only Options listed: US Equipment & Tinted Windows
> she had nother for certain on "standard 2.0 AG/PG Eqpt."
Engine Case # GA000424 - matching
Trans Case # 914/11HA0042874 (I think it is a 74, cuz mine was too worn for the 12/83 overhaul & a used case purchased)
Chassis # 5649545 ? (based on hard to read trunk stamp)
(1st 5 could be a 3, 2nd 6 could be 3 or 8, 4th could be 8, but pretty sure on rest)OE Color Code L80E Light Ivory (as I suspected)
But I'm still unsure if the Gold Metallic when I bought it 12/75 was a Dealer or First Buyer Requested Repaint by the Selling Dealership. Is it better to go back to the OE color, or to the Dealer Repaint (if I can verify such), of would it be okay to do either if it was a point-of-sale request for the Gold????Another correction to my initial post: I had a memory related brain fart, & when I looked at my California DMV Registration Cards, it indicated a first sold/registered date of 11/9/72, and my purchase/renewal cycle date as 12/26/75 -
and not the early 1976 acquisition date that I was presuming from my earliest service record date! So I've actually owned my teener a few months longer than my decrepit mind had recalled, dating back 34+ years, and purchased her just past her 3rd Birthday!
Also - given that the Gold Metallic paint wasn't super fresh & new on 12/26/75 - like a recent accident repaint would be, since I had to do a repaint in 8/76, that lends credence to it either being a dealer/initial buyer requested repaint - or at least a very early accident repair/repaint to gold!
I also found out that Calif. DMV will do research into their microfilm records under an "Information Request" at $20 per yeaqr requested (11/9/72 - 12/26/75 is only 4 years & probably well worth the $80 to fill the gap! ....especially if I can recover the missing fog lights, center console/gauges & 2.0 Fuchs Alloys from the PO/OO!!!! ...or at least answer what happened to them & why, & why/how the Gold color!?
If you're in CA & want to get this research, just go to the dmv.ca.gov website & download the "Information Request" form, fill it out & send it in with your check! ...then wait....
Okay - now for some pix, but bear with me, since I have to upload them 1 at a time due to the posts' attachment size limit. After I can figure out how to upload the full 8-900 pix to a homepage - which I'll also have to figure out how to create, then I'll post a link back at the front on my first post here.
Starting with Rear End Work.....
