Well,
I'll take a whack at it from memory. I'll probably leave some stuff out and I'm sure there is more than one way to do this so, I hope others will pipe in.
Choices:1) Use resistors (that is what was used on the 1.8l) or;
2) Use pulse width modulation to limit current to the injectors (kind of like turning a light on and off real fast, 1 more thing to tune)
3) How to trigger (you want to use MSD and that is good cause it has a nice clean signal)
Things you'll need:1) Laptop or Palm device for tuning
2)
Serial Adapter for tuning with laptop
2) Wide band O2 for tuning
3) Digital Volt Meter to test
4)
Stimulator for testing unless you can borrow one.
5)
Relay Board. This not absolutely necessary but, it helps a lot.
6) Soldering iron if you do a kit
7) Time
Fuel DeliveryFrom the tank, through the fuel circuit assuming you have carbs.
1) Tank sock
2) Supply hard lines through the center tunnel.
3) Fuel filter
4) FI fuel pump (stock or after market). I used the stock one for years and it was fine up through 2270. I am now using a
Walbro in line pump. This can be mounted up front.
5) Fuel injection hose to the passenger fuel rail (stock is fine). clamped with FI hose clamps (Use these on all of the high pressure hose).
6) Passenger fuel rail 022 133 321b
7) Injector #3 (Stock 2.0l, 1.8l or 1.7 liter !.8l injectors will accept more modern Bosch style connectors, big plus)
8) Injector #4
9) High pressure hose from the passenger side to the drivers side
10) Driver's side fuel rail 022 133 315b
11) Injector #2
12) If the rail has it you can attach a fuel pressure gauge to the bung on this rail between injectors #2 and 1.
13) Injector #1
14) High pressure hose
15) Fuel pressure regulator (Stock works pretty darn well) 039 133 551
16) High pressure hose to the return line to the tank.
Air DeliveryI used a lot of the stock 2.0l stuff. I'm not familiar with the 1.8, 1.7, or bus.
1) Stock air box 039 129 607a
2) Stock Air filter 039 129 620a
3) Stock 45 mm throttle body 039 133 063d
4) Stock plenum 039 133 055b
5) Stock hoses to connect runners to plenum 039 133 241
6) Stock intake runners and manifolds 039 133 201b
7) Stock intake manifold gaskets 039 129 707
ElectricalMegasquirt stuff1)
MS 1 kitor
1)
MS 2 kit2) Above mentioned relay board if you want
3)
Cable from relay board to ECU or this can be made.
4) Harness from relay board to engine and sensors. You gotta make this I think.
or
2) eliminate the relay board and use
DIY Autotune's harness. This looks pretty cool and wasn't available when I did mine. You would need fusing and a relay for main power and fused and relay for the fuel pump and idle air control if you use that. And, fusing for the injectors.
Power1) Switched 12V. I got it from the hot wire to the coil, 12pin connector, pin 7 on the car's relay board.
2) Good ground I took it back ti - side of the battery.
3) 12 V from the battery to supply the relays
4) Good plug wires to keep electrical noise down and resistor plugs seemed to help.
5) Shielding on the tach input for triggering MS
Sensors1) Map sensor is on the MS board. You need to run vacuum to this from the plenum to the port. It may need metering to sooth out the signal such as a filter in the line or I use a MIG welding orifice.
2) Intake air temperature, I used the stock one in the plenum. It is subject to heat soak and needs to be calibrated with a program from Megatune
3) Engine Temperature sensor. I used the stock cylinder head temperature sensor by #3 spark plug. It needs to be calibrated with Megatune.
4) Throttle position sensor. I went to the junkyard and found one that worked. It needs to turn the proper direction and have the proper shaft size. It was not easy to find.
SDS sell them and you could try there. I'm not sure about the shaft size however. This needs to be calibrated.
5) O2 sensor. Many to choose from. I use Techedge and I like it a lot.
6)
Bung for the O2 sensor7) Trigger. You mentioned MSD and that has a nice output that will trigger the injection events. I can't remember which circuit you would use in MS however.
Vacuum stuff1) MAP signal from the plenum to the MAP sensor on the MS board. As I said above it may need to be quieted.
2) Idle air. The simplest way to do this is the stock system with a auxiliary air valve 022 906 045 with switched 12V from the fuel pump circuit and vacuum line from the air cleaner to the plenum. MS1 can control an idle air valve and MS2 can control a stepper motor for idle air control.
3) Stock crankcase ventilation
4) Stock charcoal cannister for fumes.
Dave
