...Chris ...I have a set of CARRERA shocks very similar to the ohlins.
similar in that they have a threaded body and are nitrogen charged...
...my question is , how will you adapt the top mounting heim-joint to the O.E.M. top shock mount...
You can but adaptors for about $200 from The Racers Group, Rebel Racing, and probably others. I don't have oem shock towers so I will be making something myself.
...and where do you "recharge "the cannister, I don't see a fitting...
There is a fill valve on the end of the canister that you can't see in the pic.
...a suggestion as to springs/ rate would be appreciated..( stock street 914 about 2100 lbs.1973..2.o)....murray...
140-150 lb
