QUOTE(J P Stein @ Sep 8 2009, 10:03 PM)
Spend some time rootin' around in the guts of a trans and the bits leading up to it . You'll find that by its self the shifter is just something to move these aft bits around and has *little effect in ensuring that they go to the right place*. It's just a lever on a ball. It has adjustments side to side & fore & aft....you want a 500 buck lever, be my guest. The fun starts at the shift console. When ya figure out how/why/why not.... things work , then we can talk.....this would require gettin' dirty.
Hmmm, interestingly enough, i just drove a bone stock 914/6 with the stock tailshifter the other day.
The guts of the tranny are the same than on mine. Again, according to your logic, my setup with the rennshifter should not have any significant improvement over the stock 914/6 setup.
Even with all new bushings etc. the stock setup felt like stirring a pot of dough. Trying to find a gear in a hurry (think shifting fast at the track) is like playing russian roulette. Sooner or later, you'll find the wrong gear.
I'm sure with enough time and effort, you can come up with a solution that does not involve a JW unit or WEVO unit and then you can brag about how much cheaper you got your setup.
That is, if you don't value your time invested.
To me, the JW setup is a solution to a real problem.
Andy
