Now I understanf what the "1" and "15" are referring to. What the hell do the numbers refer to? Why not just use (+) and (-) ? Anyway...yes, my (+) is going to my ignition, and my (-) has two leads attached...the one to the condensor/dizzy and what I assume is a ground coming off the same bundle of wires as the ignition wire. Thanks for the PM / phone number offer...will do.
[quote name='neil30076' date='Aug 25 2009, 08:59 PM' post='1207197']
[quote name='kenshapiro2002' date='Aug 25 2009, 05:51 PM' post='1207192']
In helping me to uderstand you totally caused my head to spin
No idea what "from the switch to 15 on the coil means" What switch? 15 on the coil? What is 15 referring to?
Anyway, I changed the coil out today for a new one to no avail.
Haven't had the time yet to try the stuff you mentioned before (doing parenting), but I'll get to it tomorrow...thanks. Gonna replace condensor, points, rotor and cap. Then I'll replace the car and everything will be fine.
Ken, 1 and 15 are the numbers on the coil, and you must have them connected correctly do you have then reversed by chance - 1 goes to the distributor/condenser and tach, 15 goes to the battery via the ignition switch!
ken PM and i'll give you my phone number, feel free to call me and i'll work you through this -
[/quote]
