What is this part? |
boston914 |
Dec 1 2009, 07:23 PM
Member Group: Members Posts: 52 Joined: 15-July 03 From: Boston, MA Member No.: 912 |
In the photo below, there is a part hanging down. It looks like a cover or a sump.
I have no idea what this is. Can someone help me ID this part and its function? Thanks!!(IMG:http://i851.photobucket.com/albums/ab79/1976Porsche914/100_0981.jpg) |
r_towle |
Dec 1 2009, 07:24 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
that is the cover of your shifter at the transmission. It should be held up by a very large screw clamp on the shifter console. A few zip ties also works. Rich |
boston914 |
Dec 1 2009, 07:28 PM
Thanks.
Does the clamp go around the entire perimeter of the cover? I assume that this is there to keep dirt and grime out of the shift mechanism? Sorry for the stupid questions. I am not very mechancally inclined, but I love to drive 914s! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/laugh.gif) that is the cover of your shifter at the transmission. It should be held up by a very large screw clamp on the shifter console. A few zip ties also works. Rich |
jsayre914 |
Dec 1 2009, 07:30 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Thanks. Does the clamp go around the entire perimeter of the cover? I assume that this is there to keep dirt and grime out of the shift mechanism? Sorry for the stupid questions. I am not very mechancally inclined, but I love to drive 914s! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/laugh.gif) that is the cover of your shifter at the transmission. It should be held up by a very large screw clamp on the shifter console. A few zip ties also works. Rich yes it does |
r_towle |
Dec 1 2009, 07:31 PM
the clamp goes all the way around the top, it lays in the groove you can see on the top of the cover.
OR Run zip ties around it front the bottom all the way over the console so it stays put. Yes, it is there to keep dirt away from the grease shifter bushing in there. You should probably clean and regrease it before you put the cover back on. rich |
SirAndy |
Dec 1 2009, 10:18 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You should probably clean and regrease it before you put the cover back on. (IMG:style_emoticons/default/agree.gif) Clean, check the bushings and cone set screw, then re-grease and put it back on ... (IMG:style_emoticons/default/smash.gif) Andy |
Joe Bob |
Dec 2 2009, 01:42 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Zip ties are your friend...
type47 |
Dec 2 2009, 09:19 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
A stainless steel clamp from local hardware store (or 2 clamps put together) also works. They also should have a 4" exhaust duct clamp that could work.
Katmanken |
Dec 2 2009, 09:49 AM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
My Sears tool store used to have stainless band clamps in a huge array of sizes- including enormous ones.....
A little tape measuring, a trip to the store and ....... |
IronHillRestorations |
Dec 2 2009, 01:19 PM
I. I. R. C. Group: Members Posts: 6,730 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'll 2nd the stainless steel hose clamp. Shouldn't be too hard to find one large enought to go around, they have them here in "nearly lost" TN
eg914 |
Dec 2 2009, 10:43 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
I couldn't find a clamp that fit in the groove on the cover, but found a BIG zip tie that fits perfectly. Only bummer is you need a new tie each time. I bought a package of them.
kenshapiro2002 |
Dec 3 2009, 02:12 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
See the shit you learn on here...guess I need a cover too?
type47 |
Dec 3 2009, 03:52 PM
7TPorsh |
Dec 3 2009, 03:56 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
There's a cover that goes there??
SirAndy |
Dec 3 2009, 03:59 PM
7TPorsh |
Dec 3 2009, 04:01 PM
flipb |
Dec 3 2009, 04:02 PM
Senior Member Group: Members Posts: 1,728 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Pelican has them - mine was missing too.
You do have to disconnect the shift linkage to put it on, however... (I have to anyway because my firewall bushing was also absent!) |
kenshapiro2002 |
Dec 3 2009, 04:32 PM
This group helped me realize I was missing the throttle and clutch stops on my pedal board, and now the cover for my shift linkage, as well as some screwed up wiring in my engine compartment. Every once in awhile I just put up a shot of a certain area and let the Ninefourteenophiles have at it...constructive criticism, and all... (IMG:style_emoticons/default/lol-2.gif)
Makes me wonder what else I'm missing... |
jk76.914 |
Dec 3 2009, 05:07 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
Pic.
SirAndy |
Dec 3 2009, 05:17 PM
Slightly modified to fit my J-West shift linkage:
(IMG:http://www.914world.com/bbs2/uploads/post-179-1181191619.jpg) And more piks here: http://www.914world.com/bbs2/index.php?showtopic=72363 http://www.914world.com/bbs2/index.php?showtopic=72775 (IMG:style_emoticons/default/smash.gif) Andy |
Lo-Fi Version | Time is now: 8th June 2024 - 05:07 PM |
