> LED Brake/Taillight Group Buy
Spoke
post Apr 2 2014, 11:31 PM
Jerry
This is a group buy of what I have referred to as the 5mm LED rev 2 Brake/Taillight PCB.
These are hand assembled one by one, tested, and will be delivered as they are produced. I have made a list of folks who have shown interest in purchase from my other thread. That list is in the next post.
No need to re-request purchase if you are on the list. I will PM each member in turn. I will not request payment until your PCBs are to be assembled.
The list is in chronological order and purchase requests will be handled in order. Please be patient. If you requested boards in that thread but are not on the list, please PM me and your name will be inserted appropriately.
If you haven't previously requested a purchase and are not on the list in the next post please respond to this thread.
Many folks are familiar with work done to develop LED brake and turnsignal lights from the LED developmental thread. See the last few pages for current info as I've tried several different configurations before arriving at the 5mm rev 2 PCBs.
LED Taillight Development Thread
This 5mm rev 2 PCB is available in 3 different configurations:
1) Brake Light: RED LEDs: Price: $90/pair
2) Turnsignal: RED LEDs: Price: $90/pair
3) Turnsignal: AMBER LEDs: Price: $90/pair
Shipping:
CONUS: $10
Outside CONUS: Determined at purchase.
Each pair includes:
2 PCBs with 56 rearward facing 5mm LEDs each.
Turnsignal configuration has 8 extra side-facing LEDs to replace the small side running light. Side LEDs will be AMBER color to match your taillight lens.
Brake: Pigtail with 1157 base to plug directly into existing bulb socket.
Turnsignal: Pigtail with 1156 base (turnsignal) and 5007 base (small side light)
6 clips for each pair to mount the boards to existing taillight housing for plug-n-play installation.
1 year guarantee
Electrical Characteristics:
Brake/Turnsignal: 0.35A @ 14V (4.9Watt) each PCB
Taillight: 0.06A @ 14V (0.8Watt) each PCB
Brake Configuration:
RED Turnsignal Configuration:
Actual Boards and clips:
zambezi
post Jun 11 2014, 08:26 PM
Is there an "at home" remedy to cut the power to the turn signal LED's? I assume they are getting power from the side facing LED group. I think those being lit would be fine, but if we find the whole turn signal board being lit is a problem, is there a simple circuit we can disable to eliminate that function but still have the side LED's lit? Just asking because I installed mine today (even though the car is not yet ready for the road) and am seeing the same as everyone else. I don't have a problem with them yet but I have not used the car yet to see if it caused confusion with other drivers. I don't think any of the LEO's around these parts could care less about the legal issues of the lights, so that is not my concern.
Spoke
post Jun 11 2014, 09:01 PM
Jerry
QUOTE(zambezi @ Jun 11 2014, 10:26 PM) *
It is pretty simple to disable the amber LED array from the running lights and still have the side facing LEDs. The side facing LEDs alone should bleed very little towards the rear of the car.
See the attached pic for resistor R2. Remove this resistor and the LED array is disabled from lighting with the running lights. R2 is easy to identify as it is smaller in size as the other resistors.
There are 3 basic ways to remove R2:
1) Using 2 solder irons, heat both sides of the resistor and remove. If you have a single wide solder iron, it may be possible to lay the iron so it contacts both sides of the resistor at the same time to remove.
2) If you don't have a solder iron or can't get the resistor removed with a solder iron, you can simply crush the resistor with a pair of pliers. It may seem crude but it will work. The resistor is constructed on an alumina ceramic substrate which will shatter if compressed with a pair of pliers. Needlenose would work best. Just clean up the resistor fragments after breaking it and you're good to go.
3) Ship the boards back to me. You pay shipping to me and I'll pay shipping back. I will reimburse your shipping cost since this was my mistake.
BTW, those with red LEDs should not suffer from this legal infraction as the red running lights will only make the light footprint of the car larger at night.
Spoke   LED Brake/Taillight Group Buy   Apr 2 2014, 11:31 PM
Spoke   This is the list of folks who have requested purch...   Apr 2 2014, 11:37 PM
zambezi   You can add me to the list for a set of the red br...   Apr 3 2014, 09:54 AM
john77   Add me for a set of the brake lights and the amber...   Apr 3 2014, 11:52 AM
IanS   I'm in for a set of brakes and red turn signal...   Apr 3 2014, 11:49 AM
r_towle   I want my oompa loompa NOWWWWW or at least at Her...   Apr 3 2014, 01:37 PM
jd74914   Those are awesome! Please add me to the list f...   Apr 3 2014, 01:58 PM
chads74   Can't wait for the PM. I am excited to get the...   Apr 3 2014, 05:15 PM
scottb   if I could get in on this, pair of brake lights an...   Apr 3 2014, 05:53 PM
Spoke   One set of Brake Lights and clips. One set of T...   Apr 4 2014, 10:12 PM
Spoke   Installation of the brake light. Remove the bulb ...   Apr 4 2014, 10:24 PM
Spoke   Installation of the Turnsignal lights. Remove bot...   Apr 4 2014, 10:50 PM
Rleog   Should be no questions about this installation. N...   Apr 4 2014, 11:40 PM
CptTripps   Well done!   Apr 5 2014, 07:44 AM
Chris H.   Fantastic! I'll pay you today. EDIT: Al...   Apr 5 2014, 09:08 AM
rmdinmd   add me for one set of brake and red turn signal. ...   Apr 5 2014, 09:13 AM
Firstcar   Please add me for a set of brake light and turn si...   Apr 5 2014, 03:12 PM
Seabird   Please put me down for red brake lights. :Qarl:   Apr 5 2014, 09:00 PM
smarens   I would like a set of brake lights and a set of am...   Apr 5 2014, 09:47 PM
jim dorociak   Please put me in for brake lights and amber turn s...   Apr 5 2014, 10:04 PM
peteyd   I will get a set of the brake and red turn signals...   Apr 6 2014, 11:46 AM
Gary   A pair of brake and a pair of red turn signals ple...   Apr 6 2014, 07:01 PM
Spoke   Guys thanks for all the support. I will contact y...   Apr 6 2014, 07:54 PM
tomeric914   Well done Spoke! Can't wait! :cheer:   Apr 6 2014, 08:08 PM
lonewolfe   These LED tail lights are awesome. Do you have pla...   Apr 6 2014, 08:13 PM
Spoke   These LED tail lights are awesome. Do you have pl...   Apr 7 2014, 07:00 PM
Spoke   Experimenting with plastic clips. My colleague is ...   Apr 7 2014, 06:56 PM
monkeyboy   These LED tail lights are awesome. Do you have p...   Apr 7 2014, 11:25 PM
lonewolfe   [quote name='Spoke' post='2021995' date='Apr 7 20...   Apr 8 2014, 12:57 AM
monkeyboy   Yes. They are one of the brands that just aren...   Apr 8 2014, 08:46 AM
914forme   Please add me to the list. Red Brake lights - go ...   Apr 20 2014, 06:59 PM
lonewolfe   I'd like to be added to the list for the red b...   Apr 20 2014, 07:47 PM
Vacca Rabite   I just say this thread and WANT IN. Can I still g...   Apr 20 2014, 07:55 PM
Spoke   I just say this thread and WANT IN. Can I still ...   Apr 20 2014, 08:56 PM
Vacca Rabite   I just say this thread and WANT IN. Can I still...   Apr 21 2014, 09:35 AM
Spoke   We're switching the clips from the brass clips...   Apr 20 2014, 09:13 PM
Spoke   For the turnsignal boards, 2 long clips are used o...   Apr 20 2014, 09:27 PM
Steve   Is it to late to get added to the list? If not I w...   Apr 20 2014, 09:46 PM
palmer_md   I'm in also. Love the new clips and the side ...   Apr 21 2014, 12:39 AM
MATTYLITE   If this group buy is still being offered I'd l...   Apr 21 2014, 01:05 AM
JmuRiz   Very cool, I'm in for red brakes and turns...b...   Apr 21 2014, 08:35 AM
chads74   Spoke can you add me for a set of the red turn sig...   Apr 21 2014, 08:36 AM
wes   Very nice, I'd like to get in on the compleat ...   Apr 21 2014, 09:56 AM
Spoke   Updated the clips again. The inside turnsignal cli...   May 7 2014, 08:58 PM
CptTripps   Can I get a new set of clips? Those look a lot bet...   May 7 2014, 09:05 PM
Spoke   Can I get a new set of clips? Those look a lot be...   May 7 2014, 09:44 PM
dadaDaveed   If the group buy is still open, I'm in for a p...   May 7 2014, 10:37 PM
Rleog   I watched the development of these boards and was ...   May 14 2014, 03:46 AM
chads74   I received mine in the mail yesterday, I was so ex...   May 14 2014, 06:21 AM
tomeric914   Bumping this back up to the top. Just installed m...   May 19 2014, 09:40 PM
chads74   Drove at night again and felt very confident that ...   May 20 2014, 11:21 AM
Cupomeat   If this group buy is still Open I want a full set ...   May 20 2014, 02:46 PM
tomeric914   Tomeric got his and told me i NEED to get them......   May 20 2014, 08:19 PM
Spoke   Glad to hear the good reports. Keep me posted if y...   May 20 2014, 03:27 PM
Spoke   A couple of items about the turnsignal LEDs: ITEM...   Jun 1 2014, 08:35 PM
CptTripps   Only issue I have is the lights not blinking. This...   Jun 2 2014, 05:46 AM
SirAndy   Finally got around to installing my set. :smash: ...   Jun 5 2014, 09:39 PM
Spoke   Finally got around to installing my set. :smash:...   Jun 6 2014, 08:32 PM
SirAndy   Did you have any issues with the turnsignals not b...   Jun 7 2014, 11:33 AM
bulitt   Apologize for slight hijack- Looked into replacin...   Jun 6 2014, 04:06 AM
euro911   I remember seeing the development thread, but appa...   Jun 6 2014, 04:54 AM
smj   Hey Spoke - panels arrived a while ago, finally go...   Jun 9 2014, 01:55 AM
Spoke   Hey Spoke - panels arrived a while ago, finally g...   Jun 9 2014, 03:39 PM
CptTripps   Mine aren't blinking...just staying "on...   Jun 9 2014, 06:19 AM
SirAndy   One more thing that was brought up in the other th...   Jun 11 2014, 03:35 PM
Spoke   One more thing that was brought up in the other t...   Jun 11 2014, 08:39 PM
zambezi   Is there an "at home" remedy to cut the ...   Jun 11 2014, 08:26 PM
Spoke   Is there an "at home" remedy to cut the...   Jun 11 2014, 09:01 PM
SirAndy   It is pretty simple to disable the amber LED array...   Jun 12 2014, 11:19 AM
zambezi   Thanks, now I know how to disable it if I don...   Jun 11 2014, 09:53 PM
rmdinmd   Installed mine yesterday. Took about one hour (ye...   Jul 5 2014, 08:26 AM
Spoke   Installed mine yesterday. Everything thing seemed...   Jul 5 2014, 10:03 PM
Spoke   I've now contacted everyone on this thread who...   Jul 5 2014, 10:06 PM
euro911   PM received and Paypal sent :D   Jul 5 2014, 11:19 PM
Rleog   I've now contacted everyone on this thread wh...   Jul 6 2014, 01:22 PM
john77   Finally my ladylike slender fingers come in handy....   Jul 11 2014, 11:11 PM
eric9144   Interested in a set if you are still doing them, P...   Jul 13 2014, 09:41 AM
MATTYLITE   I'd like a set of Red Driving Lights and a set...   Jul 13 2014, 12:16 PM
Spoke   I'd like a set of Red Driving Lights and a se...   Jul 19 2014, 07:24 AM
dadaDaveed   Hey Spoke, I installed my LED's this afternoon...   Jul 28 2014, 04:25 PM
euro911   The Postman delivered mine today :) Hoping to g...   Jul 28 2014, 05:01 PM
Steve   I also got mine today, but it will be a couple of ...   Jul 28 2014, 06:55 PM
914Mike   Just seeing this today. One thing you should consi...   Aug 4 2014, 03:54 PM
mikesmith   Thanks for the R2 advice, just updated mine. A c...   Aug 4 2014, 11:45 PM
Spoke   Thanks for the R2 advice, just updated mine. A ...   Aug 5 2014, 07:18 AM
rdauenhauer   I recall reading this at the start but forgot abou...   Aug 5 2014, 09:05 AM
RJMII   hey Spoke, are you still making these?   Apr 16 2015, 11:03 AM
Chris H.   hey Spoke, are you still making these? There...   Apr 16 2015, 01:02 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:03 AM
