WAS Top - " New Saratoga top " project back in the spot light, Yes we will be back in production June-July if there is enough interest |
Mikey914 |
Feb 11 2021, 12:36 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So a few of you know we made an initial run of these some time ago (Yes it has been 10 years). We had a large learning curve and made a better product than the Saratoga tops in that they were more crude.
Ours use factory type seals, and will feature a abrasion resistant coating now that will make handling them easier for the end user (not having to be overly cautious on handling). The tooling has been redone to make the fit and finish better I plan to pull the 1st sample part and assemble mid March on these, just for myself. Thought it may be time to bring these back. Pricing will be in the $850 range for the roof with all seals and added protective costing that is more durable. This is if we get 10 takers Hardware will be available at $125 for all 4 mounting points in a non stock (custom made version) Special colors (other than charcoal smoke) will be available but may have an extra charge ($50 ish) these will be available in the initial run without any additional fabrication cost to form as they will be part of the run. You can see the blue one I did. It's pretty striking with the white interior. We have been able to make significant improvements on the original version that I plan to show in March when I can assemble the new prototype. Do we have 10 takers for the roofs? Attached image(s) |
Mikey914 |
Mar 31 2021, 05:42 PM
You got it. The list is here.
However the 1st ones will be produced without hardware. You will be able to use factory hardware. The rear we should be able to provide shortly. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:55 PM |
