GB brake reservoir covers $9 after GB $14, Codes going out 2/09/22 |
Mikey914 |
Oct 20 2021, 11:56 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have been working on this for some time now and are going into production soon.
The brake reservoir covers. I had seen these in the past and since no one wants crud on the top of the reservoir to get into the system, I decided to make these. I made these in 2 flavors, The thinner material like OEM and a material that is slightly thicker and looks more like the reservoir itself. The thicker one is the 1st prototype shown. I did actually stumble across one being used in the wild at WCR too! These will be ready in about a week. Pricing to follow shortly. You know me it will be reasonable. Mark Attached thumbnail(s) |
rhodyguy |
Oct 20 2021, 12:38 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Are you only producing the version with the overflow spigot? My cap on the 73' only has a hole. My guess is to prevent vacuum from building. The reservoir is solid around the top edge. No means for the fluid to escape. I think the spigot version requires a clear tube and the clamp differs.
Mikey914 |
Oct 20 2021, 01:58 PM
Are you only producing the version with the overflow spigot? My cap on the 73' only has a hole. My guess is to prevent vacuum from building. The reservoir is solid around the top edge. No means for the fluid to escape. I think the spigot version requires a clear tube and the clamp differs. There is a placement for the hole. They don't have to be cut out. It may be easiest just to request no hole for overflow when ordering. |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:16 AM |
