| GregAmy |
Jan 6 2022, 06:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Went to move the 914 for winter storage today and the outer door handle was INOP, acting as if the door was locked. I unlocked it with the key, no change; I went in from the passenger side to unlock it -- and it was already unlocked. Had to roll down the window so I could reach in from outside.
Behaves as expected from the inside door handle, locked and unlocked. Haven't looked at it, have not pulled the door card. Just curious if this is a known problem so I can consider buying any required parts in advance. Thanks! |
| GregAmy |
Mar 1 2022, 05:15 PM
Follow up: yup, finally got around to getting in there and the white piece of plastic is broken around its ring.
Unfortunately, so is one of of the pot metal arms that actuates it. Crap. Found the missing arm in the bottom of the door. - How do you replace the plastic part? Do I have to drill out the roll pin where it pivots? - And I'm hoping someone has a decent source for a replacement driver's side door handle? Driver quality. I don't need the lock barrel but I do need the spring, it's missing. I also found the inside of the door is bronze (it's a red car) so this thing has been through the ringer. I've given thought to re-keying the car so I can dump the VW ignition key, but I've seen asking prices for re-key sets and I'm not that motivated. My (black) Porsche key opens the two doors and the trunk, a VW key works the ignition, and nothing I have works the glovebox or front trunk cable. I don't have a valet key (I'm OK with that). Though I do have a Porsche ignition barrel in the parts box (wrong key wafers though). Must be the later style, because per this link I can put a punch in the side and the lock barrel will slide right out (chrome ring). Is someone able to re-key that to my key, and if so, will that barrel fit in my 1974? Yeah, it's a mongrel. But it's my mongrel. |
GregAmy Outer Door Handle INOP Jan 6 2022, 06:12 PM
lesorubcheek
Went to move the 914 for winter storage today and... Jan 6 2022, 06:21 PM
GregAmy Looks easy enough, I'll replace both. Thanks... Jan 6 2022, 06:52 PM
Jett It is important to note that the reason these brea... Jan 6 2022, 07:14 PM
Mikey914 Yep, just clean up and lubricate. It takes longer ... Jan 6 2022, 07:41 PM
TheCabinetmaker Jett is referring to the latch, not the lock. They... Jan 7 2022, 08:13 AM
dr914@autoatlanta.com yes the plastic door cam has broken. It was the v... Jan 7 2022, 09:23 AM
dr914@autoatlanta.com door latch cam, very first aftermarket part we eve... Mar 1 2022, 05:29 PM
Mikey914 Neither have we :D Mar 1 2022, 05:44 PM
GregAmy ...and the door handle? Plastic part don't wor... Mar 1 2022, 06:50 PM
Mikey914 They should have flex, but you are correct, if the... Mar 2 2022, 02:40 AM
GregAmy I'll concur that they are/were a mess. Yes, th... Mar 2 2022, 06:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:38 PM |
