Dual down draft Carb selection for 2056 |
technicalninja |
Feb 25 2023, 12:23 PM
Senior Member Group: Members Posts: 1,348 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I'm looking at the Empi dual down draft carb kits and had a quick question regarding differences in the carbs themselves.
It looks like they have HPMX or Dual D carbs available. Which one would you choose? Should I lean towards real Webers or Dellotos? The intention here is to use the kit in its stock form initially and later change to port fuel injection using the carbs as throttle bodies much like MB911 is doing with his EFI conversion. http://www.914world.com/bbs2/index.php?showtopic=363246 Being able to remove everything in the bores is critical for me. No fixed boosters or venturis is a requirement. I'm planning on starting with an 8.5-9.0 compression 2056 with a webcam #86. I am planning on having the final engine as a 96mm bore/78mm stroke, but this will be in the future. I believe I should start with 44 mm carbs instead of 40. Suggestions, tips, and opinions would be greatly appreciated. |
rhodyguy |
Feb 26 2023, 01:51 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Or 32s in 40s. The Venturi size is the key. Save your dough and work the 40s. A wrecked car I bought had 40s. I put the drivetrain in my car. The engine ran well. Ran out of steam at about 5.8 to 6k flat out on I-5 in Northern California returning home from the Camarillo WCR. I was focused on the road not the speedo. So the speed? (IMG:style_emoticons/default/confused24.gif) It was plenty fast for me.
Lo-Fi Version | Time is now: 10th June 2024 - 09:45 PM |
