> LED Bulb kit, Where to Buy
NARP74
post Sep 27 2023, 07:49 AM
I did a quick search, but no luck. Does anyone sell or have a list for the external LED bulbs to buy? Excluding headlights and fogs.
I did see one member that was selling these several years ago, looks like the site is NLA.
Did not want to go the full Spoke kit yet. I will buy the relay from them though.
Chris914n6
post Sep 27 2023, 01:45 PM
Jackstands are my life.
I'm cheap. I bought brake and turn LEDs from Amazon. Didn't need to change the flasher relay.
Brighter than stock but mainly it reacts faster, which is the real benefit.
Just did full LED swap on the Partzfinder (Blazer) except for the gauge bulbs that need to dim. Still north of $100 not including headlights, but worth it for safety and not draining the battery.
Spoke
post Sep 28 2023, 05:59 AM
Jerry
QUOTE(Chris914n6 @ Sep 27 2023, 03:45 PM) *
@Chris914n6
Was this on your 914? Does your 914 have an OEM flasher or LED-compatible flasher? Unless an LED has built-in ballast or ballast resistor is added, normally the OEM flasher either for the single L/R indicator in the later 914's or the separate L and R of the early 914's, the OEM flasher will not function correctly.
NARP74   LED Bulb kit   Sep 27 2023, 07:49 AM
Cairo94507   @NARP74 . Even if you do not buy anything else fro...   Sep 27 2023, 08:39 AM
NARP74   @Cairo94507 I don't see the 3rd brake light k...   Sep 27 2023, 09:14 AM
drem914   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Sep 27 2023, 09:19 AM
Cairo94507   Yes, I meant the actual brake lights on the car. ...   Sep 27 2023, 09:23 AM
NARP74   Got it. Still don't like the dot look though....   Sep 27 2023, 09:34 AM
87m491   Got it. Still don't like the dot look though...   Sep 28 2023, 09:58 AM
NARP74   Got it. Still don't like the dot look thoug...   Sep 28 2023, 10:04 AM
Cairo94507   It is a compromise for the increased safety the LE...   Sep 27 2023, 09:37 AM
NARP74   I used to work on dot matrix printers in a previou...   Sep 27 2023, 09:46 AM
Spoke   Understood about the LED 'dot' look. Witho...   Sep 27 2023, 10:43 AM
rjames   Wires can be run under the chrome strip. I used ...   Sep 28 2023, 09:24 AM
StarBear   Definitely get the brake light kit; I got the rect...   Sep 27 2023, 11:08 AM
930cabman   Are these available for the gauge lights?   Sep 27 2023, 12:02 PM
NARP74   Are these available for the gauge lights? Yes, I...   Sep 27 2023, 12:10 PM
dr914@autoatlanta.com   yes we have them   Sep 27 2023, 01:35 PM
Chris914n6   I'm cheap. I bought brake and turn LEDs from A...   Sep 27 2023, 01:45 PM
Spoke   I'm cheap. I bought brake and turn LEDs from ...   Sep 28 2023, 05:59 AM
Nogoodwithusernames   [quote name='Chris914n6' post='3104319' date='Sep...   Sep 28 2023, 10:47 AM
Mikey914   [quote name='Chris914n6' post='3104319' date='Se...   Sep 28 2023, 07:03 PM
Chris914n6   [quote name='Chris914n6' post='3104319' date='Sep...   Sep 28 2023, 06:05 PM
Spoke   I didn't think the 914 had the bulb out ...   Sep 29 2023, 03:46 AM
Mikey914   Alll things LED we do https://914rubber.com/search...   Sep 27 2023, 05:38 PM
930cabman   Alll things LED we do https://914rubber.com/searc...   Sep 28 2023, 05:11 AM
76-914   I needed to change my flasher after going to LED...   Sep 28 2023, 07:36 AM
barefoot   For gauge lighting, there are 4 different bulb hol...   Sep 28 2023, 08:50 AM
NARP74   Can start here for the bulb info; https://bowlsby....   Sep 28 2023, 09:01 AM
NARP74   Not pushing any vendor over another, shop where yo...   Sep 28 2023, 09:57 AM
StarBear   Not pushing any vendor over another, shop where y...   Sep 28 2023, 11:16 AM
Chris914n6   Not pushing any vendor over another, shop where y...   Sep 28 2023, 06:09 PM
NARP74   Since you can get colors more easily with LED, doe...   Oct 3 2023, 12:14 PM
Spoke   Since you can get colors more easily with LED, do...   Oct 3 2023, 12:59 PM
DRPHIL914   Can start here for the bulb info; [url=https://bo...   Oct 4 2023, 11:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:43 PM
