| chuckc |
Apr 23 2012, 10:44 PM
Member ![]() ![]() Group: Members Posts: 196 Joined: 30-August 10 From: Astoria NY Member No.: 12,123 Region Association: North East States |
pete000 posted a question about 914-6 Steering Column Bearings here:
http://www.914world.com/bbs2/index.php?showtopic=182165 I have a 75 1.8 that had a lot of play in the steering column when I bought it a year ago . The PO gave me both a new steering wheel bearing and the "quick fix" sleeve/bushing that could be used in lieu of replacing the bearing. I opted to replace the bearing. Also mine didn't have a Pressure Spring or a Split Ring Bushing and I didn't have one so if this is a required item please chime in. Tools needed: Upper Steering Shaft Bearing, 914 1.7/1.8/2.0 (1972-76) prt# 911-347-771-02-M100 philips head 28mm socket (for steering wheel retaining nut) breaker bar torque wrench 5.5 metric hex wrench needle nose pliers 3000 grit sand paper royal purple or wd-40 Parts: go where you'd like but you'll find 'em here w/ numbers http://www.pelicanparts.com/catalog/shopca..._SUSstr_pg2.htm time: I'm slow and had a piss poor Haynes with only general steering column disassembly instructions and it took me about 4 hours to figure out while documenting. Next time will be 1 hour. Steps: 1). remove knee pad -- 5 or 6 phillips head screws and washers on bottom. 1 small screw w/ cap on each side facing the doors. 2). remove horn, retaining nut and spring washer , and wheel. In different places I read the retaining nut was 27, 29 and 30mm, but mine was actually 28mm. final torque spec to 34 Ft-Lbs, so I used a breaker bar to loosen mine. (I made note of where the canceling ring on the back of the wheel lined up to the steering shaft since I was also swapping wheels but keeping the canceling ring.) ![]() 3). unplug 2 electrical plugs from bottom of column (you could do this as step 2, right after you removed the knee pad) ![]() ![]() 4). remove 5.5 mm hex screw on bottom of steering column ![]() 5). remove 4 long small screws from horn contact plate and the small circ clip on the end of the shaft. Now you can pull out the wiper and indicator switch assembly enough to let it hang to the side. ![]() ![]() ![]() 6). remove circ clip (a b!tc# ) it sits in a groove and can be rotated out w/ needle nose or small ice picks. Then you can remove the steering shaft bearing. The guide bushing on my bearing had rotted causing the play in the shaft. ![]() ![]() ![]() 7). prior to installing the new bearing I wiped free the broken bits of plastic from the old bushing and old grease and went over the shaft quickly w/ some 3000 grit sand paper to smooth it down a bit. The new bearing fits very, very snug so I also applied a small amount of royal purple. 8). I started the bearing with my hands, then gently tapped it with a hammer just enough to get it going then used a deep socket to get it on a bit more. My socket wasn't deep enough to finish the job so I used the old bearing as a shield and tapped away with the hammer. Getting the new bearing all the way in so that the circ clip could seat properly in its' groove took some work. I ended up tapping the bearing with a small punch the last half mm. ![]() ![]() 9). use some needle nose pliers to compress the cric clip and it will snap into its' groove then just reverse the steps to get everything together. When it came time to put the retaining nut back on I had my brother in law torque it to spec while I held the steering wheel straight. If I missed anything or screwed something up please correct me. peace, chuck Attached image(s)
| RTz |
Dec 15 2024, 08:41 AM
Newbie ![]() Group: Members Posts: 26 Joined: 18-October 24 From: Oregon City Member No.: 28,424 Region Association: None |
Part# 911-347-771-02-M100 is no longer available, so it seems. Anybody know a source or alternative?
Edit: Appears 911-347-771-02 is equivalent and still available. Can anyone confirm? |
chuckc 914-4 Steering Column Bearing replacement Apr 23 2012, 10:44 PM
wingnut86 Looks dead on.
Good pictures and flow of your pro... Apr 24 2012, 05:45 AM
chuckc
Looks dead on.
Good pictures and flow of your pr... Apr 24 2012, 01:39 PM
914-300Hemi Wingnut how did you remove the old bearing? May 10 2014, 04:29 PM
Cap'n Krusty
Yes... Jun 17 2014, 10:04 PM
HalfMoon
Ye... Jun 17 2014, 10:14 PM
florida 914
Ye... Jan 14 2015, 11:26 AM
pilothyer
[quote name='Cap'n Krusty' post='2051576' dat... Jan 14 2015, 01:04 PM
Mike Bellis Nice write up! May 10 2014, 05:11 PM
The Cabinetmaker Add one more tool. Snap ring pliers. May 10 2014, 05:35 PM
chuckc thanks Mike.
Add one more tool. Snap ring pliers... Jun 17 2014, 07:46 PM
euro911 :agree: ... nice write-up.
I need to do this on ... Jun 17 2014, 11:39 PM
billbrip
I need to do this on... Dec 26 2014, 07:35 AM
Cap'n Krusty
I need to do this o... Dec 26 2014, 11:45 AM
euro911 This is going to happen pretty soon ... my igniti... Dec 26 2014, 11:21 AM
r_towle I did this once and removing the column from the c... Dec 26 2014, 01:01 PM
euro911 Cross References: W0133-1632518
This Part Fits Yo... Jan 14 2015, 03:41 PM
lennyhope I have taken mine apart to find that someone has p... Oct 26 2016, 03:20 AM
jim_hoyland Glad this got bumped; I'm getting ready to do ... Oct 26 2016, 05:31 AM
Jett I pulled the steering column, disassembled the sha... Oct 26 2016, 09:32 AM
lennyhope
I pulled the steering column, disassembled the sh... Oct 26 2016, 01:17 PM
euro911 HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UND... Oct 26 2016, 05:30 PM
jim_hoyland
HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UN... Oct 26 2016, 05:41 PM
euro911 So it's gonna slide right up and off... :)Pre... Oct 26 2016, 08:14 PM
jim_hoyland
So it's gonna slide right up and off... :)Pr... Oct 26 2016, 08:23 PM
Aualexa1
HOW DO YOU PULL THE COLUMN?...WHAT NEEDS TO BE UN... Jul 3 2020, 10:18 PM
Aualexa1 Here’s a link to another description of this pro... Jul 4 2020, 06:41 PM
jim_hoyland Got a question: I have two bearings, the larger be... Oct 27 2016, 05:11 PM
euro911 Lookie here (2) and (6)
Oct 27 2016, 05:56 PM
jim_hoyland Hmmm.....looks like The Who assembly would have to... Oct 27 2016, 07:35 PM
euro911 I only replaced the one closest to the steering wh... Oct 28 2016, 01:38 AM
cassmcentee Couple pics of mine that I just finished...
Hope i... Jul 5 2020, 07:28 AM
wolfswest Hi,
in the first post is mentioned: Upper Steerin... Jan 23 2024, 06:32 AM
930cabman Looks straightforward, I have been wiggling my ste... Jan 24 2024, 11:00 AM
Chad911sc Both bearings lower and upper are still available.... Dec 17 2024, 01:53 PM
Chad911sc The site won’t take my pictures from my camera r... Dec 17 2024, 02:07 PM
RTz Thanks Chad, that's interesting. To clarify, y... Dec 18 2024, 06:30 PM
RTz I can confirm upper bearing part#911-347-771-02 wo... Dec 30 2024, 12:18 PM
Chad911sc Yes….if you use that sleeve that is offered on m... Jan 2 2025, 11:12 AM
RTz
Yes….if you use that sleeve that is offered on ... Jan 2 2025, 02:42 PM
Chad911sc When I replaced the factory bearing at I think aro... Jan 2 2025, 04:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th May 2026 - 02:49 AM |
