> Progress today on the 914 :), all lights working and homemade spacers
Mueller
post Mar 6 2005, 08:58 PM
914 Freak!
In order to get my car ready for it's brake and light inspection (salvage title), I finally got all of my lights to work perfectly, the aftermarket flasher relay didn't work too well so I had to dish out the $35 for a new correct unit.
I put my lathe to good use today, I needed 1/2" spacers for the rear of my car for my rims due to the heavy offset (47mm, should have been 35mm)
As you can see, I'll have to get new studs, the threads don't go down far enough for the lug nuts to tighten up against the wheel....instead of cutting new threads, I'd rather get the correct studs which have the threads formed by rolling, these make for a stronger thead....sorta like being forged.....
scotty b
post Mar 6 2005, 09:14 PM
rust free you say ?
I believe rolled threads are when the stud is formed w/out anythreads and then the threads are (for lack of a better term) Pressed into the shaft, rather than being cut. This give the splines more strenth because you are compressing the material instead of cutting it away. Corrections???
Mueller   Progress today on the 914 :)   Mar 6 2005, 08:58 PM
McMark   Nice work! I've never understood what rol...   Mar 6 2005, 09:08 PM
scotty b   I believe rolled threads are when the stud is form...   Mar 6 2005, 09:14 PM
trekkor   Welcome to 914club Mike Mueller!   Mar 6 2005, 09:32 PM
root   Mueller, Have you got a good source for rolled t...   Mar 6 2005, 09:33 PM
TimT   MIke that spacer doesnt need to be hub-centric?   Mar 6 2005, 09:34 PM
root   Oh forgot! Great job on the spacers!! ...   Mar 6 2005, 09:36 PM
scotty b     Mar 6 2005, 09:37 PM
root   I don't know but I think as long as the tires/...   Mar 6 2005, 09:39 PM
root   Lug Centric or Hub Centric? Which is it?   Mar 7 2005, 11:19 AM
Lawrence   Hi Mike! Glad to see you still around! <...   Mar 7 2005, 12:07 PM
Mueller   <...   Mar 7 2005, 12:20 PM
seanery   we missed you buddy! http://ww...   Mar 7 2005, 12:38 PM
rick 918-S   Gint   Hiya Mikey!   Mar 7 2005, 06:58 PM
Twystd1   Welcome Home... I missed ya... Twystd1   Mar 7 2005, 07:37 PM
- Lo-Fi Version Time is now: 26th November 2026 - 10:17 PM
