| Mueller |
Mar 6 2005, 08:58 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
In order to get my car ready for it's brake and light inspection (salvage title), I finally got all of my lights to work perfectly, the aftermarket flasher relay didn't work too well so I had to dish out the $35 for a new correct unit.
I put my lathe to good use today, I needed 1/2" spacers for the rear of my car for my rims due to the heavy offset (47mm, should have been 35mm) As you can see, I'll have to get new studs, the threads don't go down far enough for the lug nuts to tighten up against the wheel....instead of cutting new threads, I'd rather get the correct studs which have the threads formed by rolling, these make for a stronger thead....sorta like being forged..... Attached image(s)
| root |
Mar 6 2005, 09:39 PM
Two Wheeled Type4 Completed! ![]() ![]() ![]() Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
I don't know but I think as long as the tires/wheel/spacer hub are spun balanced
that would do the trick! Right? |
Mueller Progress today on the 914 :) Mar 6 2005, 08:58 PM
McMark Nice work! I've never understood what rol... Mar 6 2005, 09:08 PM
scotty b I believe rolled threads are when the stud is form... Mar 6 2005, 09:14 PM
trekkor Welcome to 914club Mike Mueller! ![]() ![]() |
Lo-Fi Version | Time is now: 26th November 2026 - 10:17 PM |
