> Can one remove the tranny w/o removing the engine?
Air_Cooled_Nut
post May 7 2006, 01:44 PM
914 Ronin - 914 owner who lost his 914club.com
First, I did do a search.
Second, the instructional by DNHunt is nice. Gonna really help me when I finally get to what needs to be done, which is...
Third, remove my current & tired tranny and install a true, rebuilt unit (from my last teener).
Can I remove my old tranny without having to drop the engine? If not, how far does the engine need to drop? For example, just lower it down a couple inches and thus leave all the FI and stuff attached (I don't know, I'm asking)? Help here would be appreciated. Yes, I've dropped my engine before but it's a PITA, removing and installing, and I really don't want to do it if at all possible.
I will be replacing my end cover since the one on my rebuilt tranny has broken ears. Any "gotchas"/suggestions? I did learn that if you rest the tranny vertically so the bell housing is resting on your work bench, oil will drain out the top breather... (IMG:style_emoticons/default/owned.gif) guess I'll need to drain the oil inside before replacing stuff, right?
Air_Cooled_Nut   Can one remove the tranny w/o removing the engine?   May 7 2006, 01:44 PM
Porsche Rescue   Easy. Support engine from below, remove exhaust, t...   May 7 2006, 01:54 PM
Aaron Cox
  May 7 2006, 08:21 PM
So.Cal.914   No you do not have to drop engine. Renove air box ...   May 7 2006, 01:56 PM
kobas   I've done this, it was easy lowering the trann...   May 7 2006, 07:14 PM
davep   Dropping the tranny by itself is no real problem. ...   May 7 2006, 08:07 PM
Twystd1   What Davep said.... Twystd1   May 7 2006, 08:10 PM
messix   just look for that sum'bitch top bolt and nut ...   May 7 2006, 08:18 PM
Twystd1   Putting together a trany and engine on the floor i...   May 7 2006, 08:26 PM
davep
- Lo-Fi Version Time is now: 3rd August 2026 - 05:36 PM
