| Air_Cooled_Nut |
May 7 2006, 01:44 PM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
First, I did do a search.
Second, the instructional by DNHunt is nice. Gonna really help me when I finally get to what needs to be done, which is... Third, remove my current & tired tranny and install a true, rebuilt unit (from my last teener). Can I remove my old tranny without having to drop the engine? If not, how far does the engine need to drop? For example, just lower it down a couple inches and thus leave all the FI and stuff attached (I don't know, I'm asking)? Help here would be appreciated. Yes, I've dropped my engine before but it's a PITA, removing and installing, and I really don't want to do it if at all possible. I will be replacing my end cover since the one on my rebuilt tranny has broken ears. Any "gotchas"/suggestions? I did learn that if you rest the tranny vertically so the bell housing is resting on your work bench, oil will drain out the top breather... (IMG:style_emoticons/default/owned.gif) guess I'll need to drain the oil inside before replacing stuff, right? |
| So.Cal.914 |
May 7 2006, 01:56 PM
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
No you do not have to drop engine. Renove air box if it is a clearance problem.
Put jack under trans and unbolt lower trans mounts and lower until it is clear to remove. Than take note how much you will have to block up engine at rear. Jack up engine/trans and place blocks in front of trans at rear of block to support engine. When you replace tail cover, replace the gasket. Iam sure you can take it from here. Have fun. (IMG:style_emoticons/default/smoke.gif) |
Air_Cooled_Nut Can one remove the tranny w/o removing the engine? May 7 2006, 01:44 PM
Porsche Rescue Easy. Support engine from below, remove exhaust, t... May 7 2006, 01:54 PM
Aaron Cox
kobas I've done this, it was easy lowering the trann... May 7 2006, 07:14 PM
davep Dropping the tranny by itself is no real problem. ... May 7 2006, 08:07 PM
Twystd1 What Davep said....
Twystd1 May 7 2006, 08:10 PM
messix just look for that sum'bitch top bolt and nut ... May 7 2006, 08:18 PM
Twystd1 Putting together a trany and engine on the floor i... May 7 2006, 08:26 PM
davep ![]() ![]() |
Lo-Fi Version | Time is now: 3rd August 2026 - 05:36 PM |
