| Air_Cooled_Nut |
May 7 2006, 01:44 PM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
First, I did do a search.
Second, the instructional by DNHunt is nice. Gonna really help me when I finally get to what needs to be done, which is... Third, remove my current & tired tranny and install a true, rebuilt unit (from my last teener). Can I remove my old tranny without having to drop the engine? If not, how far does the engine need to drop? For example, just lower it down a couple inches and thus leave all the FI and stuff attached (I don't know, I'm asking)? Help here would be appreciated. Yes, I've dropped my engine before but it's a PITA, removing and installing, and I really don't want to do it if at all possible. I will be replacing my end cover since the one on my rebuilt tranny has broken ears. Any "gotchas"/suggestions? I did learn that if you rest the tranny vertically so the bell housing is resting on your work bench, oil will drain out the top breather... (IMG:style_emoticons/default/owned.gif) guess I'll need to drain the oil inside before replacing stuff, right? |
| Twystd1 |
May 7 2006, 08:10 PM
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
What Davep said....
Twystd1 |
Air_Cooled_Nut Can one remove the tranny w/o removing the engine? May 7 2006, 01:44 PM
Porsche Rescue Easy. Support engine from below, remove exhaust, t... May 7 2006, 01:54 PM
Aaron Cox
So.Cal.914 No you do not have to drop engine. Renove air box ... May 7 2006, 01:56 PM
kobas I've done this, it was easy lowering the trann... May 7 2006, 07:14 PM
davep Dropping the tranny by itself is no real problem. ... May 7 2006, 08:07 PM
messix just look for that sum'bitch top bolt and nut ... May 7 2006, 08:18 PM
Twystd1 Putting together a trany and engine on the floor i... May 7 2006, 08:26 PM
davep ![]() ![]() |
Lo-Fi Version | Time is now: 3rd August 2026 - 05:35 PM |
