> Lift Installation How Hard?
Ferg
post May 9 2006, 09:10 AM
I bought a 4 post Bend Pac Lift that is currently installed in the sellers garage. It is the type that MUST be bolted to the cement slab, and is not a free standing 4 post. I'm trying to decide how to move it to my garage and reinstall it.
I've got access to a trailer and 3 or 4 buddies are willing to help, my concern is the setup. Since this lift must be anchored with impact cement bolts, leveled, aligned and shimed in order to function proplerly, i'm a little concerned about doing it "RIGHT".
I have called some people and I can hire a professional to take it down, transport it and set it up correctly for 1k, alot of money for sure, but i'll know it's done right.
Looking for some been there done that from the group. If it was a stand alone four post I'd do it myself no problem, i'm leaning towards paying to have it done.
What would you guys do?
Ferg (IMG:style_emoticons/default/biggrin.gif)
McMark
post May 9 2006, 10:00 AM
914 Freak!
I'd install it myself. Careful measurements are probably key with a four post lift. The two post I helped install wasn't hard at all since we only had to measure the distance between the two posts.
Ferg   Lift Installation How Hard?   May 9 2006, 09:10 AM
McMark   I'd install it myself. Careful measurements a...   May 9 2006, 10:00 AM
LvSteveH   I'm sure Bend Pac can send you the original in...   May 9 2006, 10:18 AM
TROJANMAN   when in doubt.............write a check. :) i...   May 9 2006, 10:25 AM
URY914   I would do it myself but I'm a construction gu...   May 9 2006, 10:40 AM
Ferg   Good stuff, just found another company that will d...   May 9 2006, 10:43 AM
elwood-914   I've installed one once. Your garage should no...   May 9 2006, 10:48 AM
URY914   Does the seller still have the installation instru...   May 9 2006, 10:52 AM
TROJANMAN   Ferg, if you are not sure how thick your concrete...   May 9 2006, 10:56 AM
Ferg   Thanks everyone, I just called Boulder County, the...   May 9 2006, 11:17 AM
URY914   $700 is money well spent. BTW, don't wa...   May 9 2006, 11:31 AM
Bartlett 914   I would install it myself. Make sure it is square ...   May 9 2006, 11:42 AM
obscurity   One thing to be concerned with is not so much what...   May 9 2006, 12:55 PM
URY914
- Lo-Fi Version Time is now: 25th May 2026 - 05:53 PM
