| Ferg |
May 9 2006, 09:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
I bought a 4 post Bend Pac Lift that is currently installed in the sellers garage. It is the type that MUST be bolted to the cement slab, and is not a free standing 4 post. I'm trying to decide how to move it to my garage and reinstall it.
I've got access to a trailer and 3 or 4 buddies are willing to help, my concern is the setup. Since this lift must be anchored with impact cement bolts, leveled, aligned and shimed in order to function proplerly, i'm a little concerned about doing it "RIGHT". I have called some people and I can hire a professional to take it down, transport it and set it up correctly for 1k, alot of money for sure, but i'll know it's done right. Looking for some been there done that from the group. If it was a stand alone four post I'd do it myself no problem, i'm leaning towards paying to have it done. What would you guys do? Ferg (IMG:style_emoticons/default/biggrin.gif) |
| obscurity |
May 9 2006, 12:55 PM
Member ![]() ![]() Group: Members Posts: 412 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
One thing to be concerned with is not so much what the code said the slab thickness should be but what the contractor actually poured. There is a lot less quality control in residential construction.
I didn't notice if you listed the houses age but the 2000 International Building Code (currently enforced in many parts of the country) states that the minimum thickness for concrete slab on grade floors is 3.5" (section 1911) Hope this helps, |
Ferg Lift Installation How Hard? May 9 2006, 09:10 AM
McMark I'd install it myself. Careful measurements a... May 9 2006, 10:00 AM
LvSteveH I'm sure Bend Pac can send you the original in... May 9 2006, 10:18 AM
TROJANMAN when in doubt.............write a check. :)
i... May 9 2006, 10:25 AM
URY914 I would do it myself but I'm a construction gu... May 9 2006, 10:40 AM
Ferg Good stuff, just found another company that will d... May 9 2006, 10:43 AM
elwood-914 I've installed one once. Your garage should no... May 9 2006, 10:48 AM
URY914 Does the seller still have the installation instru... May 9 2006, 10:52 AM
TROJANMAN Ferg,
if you are not sure how thick your concrete... May 9 2006, 10:56 AM
Ferg Thanks everyone, I just called Boulder County, the... May 9 2006, 11:17 AM
URY914 $700 is money well spent.
BTW, don't wa... May 9 2006, 11:31 AM
Bartlett 914 I would install it myself. Make sure it is square ... May 9 2006, 11:42 AM
URY914 ![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 06:37 PM |
