| Mikey914 |
May 31 2013, 12:16 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I had a request to find all the group buys and it seems most appropriate to post the open threads here. So as I add them, I'll list them. If you want in on an open thread, just add to it (you can PM me but I'll probably never find it).
I do want to thank everyone here for supporting my efforts in making these parts, it's been 5 years and I went from 1 part to over 130. Sincerely Mark W AKA Mikey914 ___________________________________________________________ I realize there are a few threads that I've got open as GB's that are being fulfilled very slowly or being refined further they will be added in as they are brought up to speed Current open threads with product open and shipping Parts in production - OEM style front turn signal seals http://www.914world.com/bbs2/index.php?sho...mp;hl=Group+buy Front trunk pull with sheath http://www.914world.com/bbs2/index.php?showtopic=236741 Sway Bar bushings http://www.914world.com/bbs2/index.php?showtopic=236676 Wiper grommets http://www.914world.com/bbs2/index.php?showtopic=236670 Door light switch gaskets http://www.914world.com/bbs2/index.php?showtopic=236674 Hand throttle for carbed cars GB $120 maybe less $99?, My source in Germany has discontinued now I'm stepping up http://www.914world.com/bbs2/index.php?sho...29649&st=25 Group buy 2.0 throttle body to plenum rubber sleve, 039.133.073 ? $10.20 these will be $16.80 after http://www.914world.com/bbs2/index.php?showtopic=231660 Group buy wiper assembly offset standoff, $6.80 each, $12 after the GB http://www.914world.com/bbs2/index.php?showtopic=231661 New rear targa seal with fuzzie- http://www.914world.com/bbs2/index.php?sho...=220677&hl= Anticipated metal inserts available 3/22 Open threads with product shipping - Yes another GB Side marker lens seals, a set of the "new and improved" $8 (for both) $12 after http://www.914world.com/bbs2/index.php?sho...amp;hl=triangle Closed GBs > LAST DAY- The coveted triangle window seals! Closes Feb 14th, GB $92 a set..+shipping. Yes left and right! ? $120 after http://www.914world.com/bbs2/index.php?sho...amp;hl=triangle New parts that I'm making - Carpet grommets, GB-$4.40 large , $2.99 for the ones that hold the front carpets anticipated 10/18/13 link- http://www.914world.com/bbs2/index.php?showtopic=211270 Heater lever cable nipples - http://www.914world.com/bbs2/index.php?act...=0#entry1934252 Another GB - $8.40 a set Water drain grommets, The ones for the hoses on the funnels. http://www.914world.com/bbs2/index.php?showtopic=216019 GB- The original window scrapers, These are the ones correct for the 6's " New" old style window scrapers $8.50 each (you will need 2). http://www.914world.com/bbs2/index.php?showtopic=217109 Another GB Trunk lock gasket Will be ready W turn signal boots, $2.75 + shipping will be ready with turn signal boots link- http://www.914world.com/bbs2/index.php?showtopic=213720 Thread title- I think everyone may want these - New part GB, Turn signal crack pipes (rubber cover boots) $26 a PAIR!!!! link- http://www.914world.com/bbs2/index.php?showtopic=211358 Title -Flexdam GB reopened, Flexdams at $105 rubber at $55 Anticipated product - Airdams in stock - Rubber IN STOCK link- http://www.914world.com/bbs2/index.php?sho...209472&st=0 Shock cap covers- thinking of making these, Who's interested at $9.99 a set? link- http://www.914world.com/bbs2/index.php?showtopic=200727 GB -Eyebrow grommets set of all 4.99, Made from silicone easier to install Link- http://www.914world.com/bbs2/index.php?showtopic=207560 GB - $8.20 + shipping the Side shift rear bellows was NLA, Fits at the rear over the rod at the plastic cover --GB closes June 16th link- http://www.914world.com/bbs2/index.php?showtopic=207565 Snorkel Tube wiring harness GB $28 each, These will be $45 after the GB Link- http://www.914world.com/bbs2/index.php?showtopic=200378 GB - front trunk "nose plugs" set of all 9 - silicone, $22 a set will be $40 a set after GB Link- http://www.914world.com/bbs2/index.php?showtopic=207561 Fiberglass door panels with vinyl http://www.914world.com/bbs2/index.php?sho...fiberglass+door |
| Mikey914 |
Jun 27 2013, 07:17 PM
Flex dams and rubber now shipping
| Mikey914 |
Jul 3 2013, 12:01 PM
revised for turn signal boots and trunk lock gasket
Attached thumbnail(s) |
| Mikey914 |
Aug 16 2013, 10:40 AM
Updated with new products
| Mikey914 |
Oct 1 2013, 12:11 AM
Nipples and carpet grommets added
| Mikey914 |
Mar 6 2014, 02:59 AM
More new parts
| Mikey914 |
Jun 2 2014, 01:24 AM
OEM style front turn signal seals http://www.914world.com/bbs2/index.php?sho...mp;hl=Group+buy Front trunk pull with sheath http://www.914world.com/bbs2/index.php?showtopic=236741 Sway Bar bushings http://www.914world.com/bbs2/index.php?showtopic=236676 Wiper grommets http://www.914world.com/bbs2/index.php?showtopic=236670 Door light switch gaskets http://www.914world.com/bbs2/index.php?showtopic=236674 |
| Mikey914 |
Sep 4 2015, 08:02 PM
Don't miss out on your chance to get a new dash top for less than 1/2 what others want for one -
http://www.914world.com/bbs2/index.php?sho...3410&st=250 And confirmed fit on early too. Attached image(s)
Lo-Fi Version | Time is now: 9th June 2026 - 04:14 PM |
