914 runoffs, Q gear |
fp racer |
Jul 18 2014, 10:18 PM
Newbie Group: Members Posts: 15 Joined: 25-December 09 From: san jose ca. Member No.: 11,172 Region Association: None |
I want to buy a Q gear for a 901. Anybody have one for sale? thanks
fasthonda |
Jul 20 2014, 08:53 AM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
race914 |
Jul 22 2014, 08:46 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
fp racer |
Jul 23 2014, 10:10 AM
I want to buy a Q gear for a 901. Anybody have one for sale? thanks I have a Q 4th available. Will PM you. Hey FP Racer, What ratio setup are you planning to run at Laguna? Not sure what ratio I will use. I'm trying to work that out now. Any advice ? |
race914 |
Jul 23 2014, 10:39 AM
I want to buy a Q gear for a 901. Anybody have one for sale? thanks I have a Q 4th available. Will PM you. Hey FP Racer, What ratio setup are you planning to run at Laguna? Not sure what ratio I will use. I'm trying to work that out now. Any advice ? My 914 is a 4 with around 150hp and around 1900lbs and I run Ka-Q-V which works pretty well for me. With our 914-6 which was around 240hp and 2100lbs I ran M-S-X With the 4 I actually hit top speed between 4 and 5 not down the straight since that is somewhat uphill.. and the incline from 6 to the corkscrew is rough on my 4, but I can run the V and still 'somewhat' continue to accelerate. What are you running now? |
fp racer |
Jul 24 2014, 10:27 AM
Right now I'm running MSX. I have about 150hp. I never use 5th so I need to change the gearing around.
race914 |
Jul 24 2014, 12:28 PM
Right now I'm running MSX. I have about 150hp. I never use 5th so I need to change the gearing around. Know what you mean. M-S-X worked great in the 6 but that was a 3.2 Ka-Q-V seems to work the best with my 4 at Laguna. I think you'll like the 'Q' for 4th. The 'Ka' 3rd works great for turn 2 and 8. And I moved 'V' from 4th to 5th and just about redline end of the main straight, also just as I reach turn 5, and I can still accelerate up the hill to the corkscrew, nothing dramatic but still gaining some speed. Pretty good setup for me anyway at Laguna. Here's the RPM/MPH chart for this setup Do you still have the stock 5th 'ZD' to flip to make the 'Ka' 3rd? Attached File(s) 914_901_A_F_Ka_Q_V.pdf ( 21.3k ) Number of downloads: 28 |
bam914 |
Jul 24 2014, 06:05 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
I used I N S V in my FP 914. It is nice having a usable 2nd gear.
campbellcj |
Jul 27 2014, 11:58 AM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I just did my first time trial at Laguna with GA/Ka/Q/V; a lot of rowing between 3rd and 4th but it kept my high-revving 6 in the powerband nicely. I experimented with using 5th on the two longest straights vs. just holding 4th; not sure which was quicker (damn data acq malfunctioned.)
race914 |
Jul 28 2014, 09:00 AM
I just did my first time trial at Laguna with GA/Ka/Q/V; a lot of rowing between 3rd and 4th but it kept my high-revving 6 in the powerband nicely. I experimented with using 5th on the two longest straights vs. just holding 4th; not sure which was quicker (damn data acq malfunctioned.) I could run a gear sheet for your redline on your 6 if that would help out.... |
campbellcj |
Jul 28 2014, 09:20 AM
race914 |
Jul 28 2014, 09:59 AM
Wow... How time flies... That sheet has been around for years!
http://www.914world.com/bbs2/index.php?showtopic=79893 Would be cool if you'd post your car info (weight, cc, hp, redline, etc) along with your gear set info there for others to reference... I've got a new setup I'm about to post after I get some data on how it's doing. |
campbellcj |
Jul 29 2014, 11:15 AM
Wow... How time flies... That sheet has been around for years! http://www.914world.com/bbs2/index.php?showtopic=79893 Would be cool if you'd post your car info (weight, cc, hp, redline, etc) along with your gear set info there for others to reference... I've got a new setup I'm about to post after I get some data on how it's doing. Same here! Same trans and gearset but I'm now running a fresh engine, flares, wider wheels and different tires. I need to get the car weighed and dyoed, probably in September as I may be changing POC classes and getting classed for VARA (which I'm 98% sure will be GTU). |
race914 |
Jul 30 2014, 03:56 PM
FP Racer,
My best advice is.... 1) Start with the corner that leads to the longest straight 2) Measure the fastest MPH you can take that turn 3) Go to the Gear Chart and find the gear that puts you at the best "entry power band" at that speed. For example my 4 "comes on" at 4000 Rpm so I want to enter that corner at 4000 RPM and then RIP IT! 4) Find that gear that puts you in that power band at that MPH. That's what you need for that corner. 914 World Gear Sheet The corner onto the longest straight is the most important... Then take it from there and do the same for the other corners. |
race914 |
Jul 30 2014, 04:10 PM
FP Racer, My best advice is.... 1) Start with the corner that leads to the longest straight 2) Measure the fastest MPH you can take that turn 3) Go to the Gear Chart and find the gear that puts you at the best "entry power band" at that speed. For example my 4 "comes on" at 4000 Rpm so I want to enter that corner at 4000 RPM and then RIP IT! 4) Find that gear that puts you in that power band at that MPH. That's what you need for that corner. 914 World Gear Sheet The corner onto the longest straight is the most important... Then take it from there and do the same for the other corners. Now I kinda feel like this guy (IMG:http://www.914world.com/bbs2/uploads_offsite/www.taped.biz-5027-1406758227.1.jpg) Don't hate me for knowing what I'm doing.... and sharing... The way I see it, if our cars are all equal it's down to the driver.... That's the real test |
fp racer |
Jul 30 2014, 05:55 PM
brant |
Jul 30 2014, 09:25 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
FJOSV
fp racer |
Jul 30 2014, 11:21 PM
brant |
Jul 30 2014, 11:41 PM
It's a box for all tracks. 4 gears for short tracks and 5 gears for long tracks.
The 4 useable gears are as good and close ratio as most boxes that have an A first that is not used. FJOS is a good set of ratios on most tracks V is only 900 rpm's different than 4th |
fp racer |
Jul 30 2014, 11:59 PM
It's a box for all tracks. 4 gears for short tracks and 5 gears for long tracks. The 4 useable gears are as good and close ratio as most boxes that have an A first that is not used. FJOS is a good set of ratios on most tracks V is only 900 rpm's different than 4th That might work but I'm having a hard time finding any gears I need. Plus I'm not going to mortgage the house to buy them. Lol |
Lo-Fi Version | Time is now: 7th May 2024 - 07:09 AM |
