HELP -- Need guidance on removing 73 914 2.0 wiring harness, Trouble removing rear main harness -- any tips? |
Jett |
Jul 27 2014, 11:58 AM
Senior Member Group: Members Posts: 1,637 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Hello, we are in the process of doing a full restoration on a rescued (sitting in mud since 1989) all original, 1973 Porsche 914S 2.0 - Delphi Green Metallic.
Currently we are removing the complete wiring harness and am having trouble feeding the rear harness thru the rear chassis tube and firewall. Do I need to remove the corresponding connectors from the fuse box and then feed the harness out the back? I thought it possible to leave all fuse box connections in place (IMG:style_emoticons/default/smile.gif) and feed the engine harness through the firewall to the cabin. Any help would be greatly appreciated... |
scotty b |
Jul 27 2014, 12:07 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
everything can be pulled into the pass cabin without having to remove the fuse panel. About the only parts you need to remove/reinstall are some of the large connectors I.E. the headlights, and multi terminals. I don't have any real info other than feed the smaller half through first rather than try and feed all at once
Jett |
Jul 27 2014, 01:02 PM
everything can be pulled into the pass cabin without having to remove the fuse panel. About the only parts you need to remove/reinstall are some of the large connectors I.E. the headlights, and multi terminals. I don't have any real info other than feed the smaller half through first rather than try and feed all at once Thanks for the response. The front was no issue but more focused on the rear portion and techniques to get the rear portion thru the firewall. |
SirAndy |
Jul 27 2014, 01:20 PM
Resident German Group: Admin Posts: 41,618 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
This thread has some good info about removing/installing a main harness:
http://www.914world.com/bbs2/index.php?showtopic=13582 (IMG:style_emoticons/default/smile.gif) PS: (IMG:style_emoticons/default/welcome.png) |
JeffBowlsby |
Jul 27 2014, 02:15 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Remove the 14-pin relay board connector housing, the fuel pump connector housing and the oil temp sender wire connector housing. Lube up the rubber snorkel tube grommet good...use KY jelly or glycerin, they clean up easily without leaving a residue.
No need to cut anything. |
Mike Bellis |
Jul 27 2014, 02:33 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
It is a pain but it can be done... 914s... (IMG:style_emoticons/default/happy11.gif) |
Jett |
Jul 27 2014, 06:39 PM
(IMG:style_emoticons/default/welcome.png) It is a pain but it can be done... 914s... (IMG:style_emoticons/default/happy11.gif) Thanks all for the ecouragment... We got the harness out, but removed the snorkel as it was already damaged. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 04:13 AM |
