Electric windshield washer pump question, Can I power the pump with the brown wire ? |
johannes |
Apr 5 2015, 10:08 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
I have a 75 1.8. I want to install an electric winshield washer pump. I want to do this as simple as possible. I bought a small pump. The small plastic bit on the switch is already broken so I have the "intermittent wipers" position available. I have located the brown wire behind the gas tank.
I wanted to power the pump directelly from the brown wire so I have the pump working when I have the switch is on the bottom position. I don't need to have the wipers working at the same time. I only wanted to put an "on line" autoradio like fuse before the pump. Will it work ? will the switch handle the (little) power of the pump without using a relay ? Has someone already done that? |
Bruce Hinds |
Apr 5 2015, 10:10 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Brown wires are ground.
Spoke |
Apr 5 2015, 11:23 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You won't need a relay to run the washer pump. You can use the brown wire as long as you trace where it goes and are sure that it is powered (12V) when energized. Otherwise, it could be a ground wire and attached to the chassis somewhere.
StratPlayer |
Apr 5 2015, 11:46 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
johannes |
Apr 5 2015, 04:13 PM
johannes |
Apr 5 2015, 04:15 PM
I knew this page? My question was because I don't have the relay harness. |
BeatNavy |
Apr 5 2015, 04:31 PM
There is an extra brown/black wire that runs to the steering column. I did use that one to power the windshield pump with the different wiper switch. Here's a thread where I "discovered" that wire (post 24): Wiring Windshield Washer.
Apr 5 2015, 05:38 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If i recall correctly, the brown/black wire has 12V when the lever is pull towards you. That should be enough to power the pump.
http://www.914world.com/specs/tech_el_washer.php However, i would recommend using an aftermarket relay anyways, they're usually always the better choice. (IMG:style_emoticons/default/smile.gif) |
johannes |
Apr 6 2015, 04:31 AM
Thank's all of you for your answers.
johannes |
Apr 6 2015, 04:32 AM
I will post pictures when done.
Apr 6 2015, 09:30 AM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Actually, you may be in the best position to answer your question: Check the wire with a voltmeter. If it has +12V when you pull the stalk back, and not at any other time, it should be fine to power the pump.
And Andy is quite right, using a relay will help the switch not to work so hard, and can make sure you get full power to the pump when you want it. --DD |
stinkindiesel |
Apr 6 2015, 01:06 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
You'd really need to know the current requirements of the pump you have and the pull current of the relay you are considering. I wouldn't be surprised if a standard automotive relay pull current isn't very close to the run current of many of the modern small electric pumps used for windshield washers. If that's the case, the relay isn't really a win.
All pure speculation on my part, and I'm too lazy to do the research :^) Gary |
914_teener |
Apr 6 2015, 06:04 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
You'd really need to know the current requirements of the pump you have and the pull current of the relay you are considering. I wouldn't be surprised if a standard automotive relay pull current isn't very close to the run current of many of the modern small electric pumps used for windshield washers. If that's the case, the relay isn't really a win. All pure speculation on my part, and I'm too lazy to do the research :^) Gary I just did this one per Andy's thread he has re-posted. I used a URO pump....it works great. |
worn |
Apr 6 2015, 08:42 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Actually, you may be in the best position to answer your question: Check the wire with a voltmeter. If it has +12V when you pull the stalk back, and not at any other time, it should be fine to power the pump. And Andy is quite right, using a relay will help the switch not to work so hard, and can make sure you get full power to the pump when you want it. --DD Having purchased several 924 wiper stalk switches in quest of wiper washer bliss i can say that the switches were not overengineered. Lots of softened overheated plastic. So run the relay to bolster the 12 v that i think you should find. If you have the wire you could go whole hog and intermittent the wipers too. But as you point out, you already know that. Best of luck. |
johannes |
Apr 8 2015, 06:29 AM
Having purchased several 924 wiper stalk switches in quest of wiper washer bliss i can say that the switches were not overengineered. Lots of softened overheated plastic. So run the relay to bolster the 12 v that i think you should find. If you have the wire you could go whole hog and intermittent the wipers too. But as you point out, you already know that. Best of luck. I searched on the Interweb and found many sources that tell the windshield washer pumps draw 4 to 5 amps, the motob being about 50 Watts. I wasn't able to check on the pump I purchased. There is nothing written on and I have nothing to mesure current. With so many amps. it It may be unsafe to run the pump directelly from the wiper switch. I will go the relay way. ... |
Valy |
Apr 8 2015, 03:12 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
http://www.914world.com/bbs2/index.php?sho...4&hl=wipers
All you need to know. That wire for the intermitent relay will not work well for the pump. |
stinkindiesel |
Apr 8 2015, 03:57 PM
QUOTE I searched on the Interweb and found many sources that tell the windshield washer pumps draw 4 to 5 amps, the motob being about 50 Watts. I wasn't able to check on the pump I purchased. There is nothing written on and I have nothing to mesure current. With so many amps. it It may be unsafe to run the pump directelly from the wiper switch. I will go the relay way. ... If the pump is really in the 4-5A range, I'd definitely go with a relay. I'm a little surprised, though, that such a small electric motor would require so much juice. Gary |
Cap'n Krusty |
Apr 8 2015, 08:53 PM
johannes |
Apr 9 2015, 01:33 AM
http://www.914world.com/bbs2/index.php?sho...4&hl=wipers All you need to know. That wire for the intermitent relay will not work well for the pump. Lots of very interresting informations in this thread. Thank you for pointing it to me. I like your switch hack ... Very smart. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:57 PM |
