I have a 75 1.8. I want to install an electric winshield washer pump. I want to do this as simple as possible. I bought a small pump. The small plastic bit on the switch is already broken so I have the "intermittent wipers" position available. I have located the brown wire behind the gas tank.
I wanted to power the pump directelly from the brown wire so I have the pump working when I have the switch is on the bottom position. I don't need to have the wipers working at the same time. I only wanted to put an "on line" autoradio like fuse before the pump. Will it work ? will the switch handle the (little) power of the pump without using a relay ?
Has someone already done that?
