Anyone replace the speedo cable?, What am I not getting? |
tygaboy |
Mar 7 2017, 09:32 AM
914 Guru Group: Members Posts: 5,297 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I'm working on my '74 1.8 and among other things, the speedo cable housing was cracked at the angle drive so I ordered a new one from Pelican.
I go to replace it by cutting the damaged end off and pulling the cable into the cabin. I haven't yet disconnected the other end from the speedo. I figured I'd do all the dirty work under the car first. As I go to feed the new cable from under the car into the interior, the end that connects to the speedo won't fit through the opening in the firewall - it's too big. The end that connects to the trans is even bigger. The Hayes manual is no help. Not even a picture. NOTE: I purchased the cheap GEMO product vs OEM. Later today I hope to pull the speedo end and see if it's smaller but has anyone had this same issue or am I missing something simple here...? (IMG:style_emoticons/default/WTF.gif) I'll also call Pelican and see if they can help. Thanks, Chris Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:47 PM |
